Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not spin nor agitate
My washer appears to fill properly and drin properly; however, it will no longer spin or agitate. I can't see any belts under this model. It seems that the motor is running...a little louder than before, but it's running.
  • Mike Nituob Apr 02, 2007
    Cat! You are the MAN! I got the part at Peru Hardware, $18.00 and in went in! Less than thirty minutes. I can't believe it was so easy!!!
    THANK YOU!!
    MJB
    President:
  • 878 Answers
Mj, sounds like a broken coupler, look at number 13 on the picture. The fact that it won't agitate or spin but will drain rules out the lid switch. This is not a hard job. Check this out first. Catriver..post back
Posted on Apr 02, 2007
My roper washing machine will fill with water, but will not agitate, rinse or spin, but will drain. It makes a horrible noise during all cycles except when filling with water. What is or could be the...
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Roper Washing Machines
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Jul 24, 2014 | Whirlpool Washing Machines
W600 fornt load washer does not wash or spin. It does fill and drain fine.
Jan 12, 2014 | Asko W600
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Sep 30, 2012 | Roper Washing Machines
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
The washer fills and drains, but won't agitate
sounds like the clutch is not properly engaging and if this is the case it usually meens it has to be replaced
Oct 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
161 people viewed this question
Sal De
Marvin
Marvin
jimorris77
