Question about Dell Latitude C610 1.2GHz - 256MB - 20GB - CDRW (DELLC6101225620CDRW) PC Notebook
Fan I very rarely hear my fan running. Is that normal or should it be replaced quickly?
  • 624 Answers
For laptops this is normal. They only come on when a sensor indicates the temperature has exceeded a safe level. Let us know if you have any other questions and thanks in advance for rating this posting.
Posted on Apr 01, 2007
Why does my car stereo overheat after 15-20 minutes?
There clearly is a fault. Probably with the output or driver stage bias. Something is getting hot and as it heats its value is changing. It will probably need an engineer with a service sheet to locate the fault. It is rarely the obvious culprit...
Apr 10, 2016 | Car Audio & Video
How to check if my fans work in my 1992 subaru impreza
I assume you mean engine cooling fans. The primary fan is bolted to the water pump and turns with the engine-always runs. The other fan is for when the engine begins to overheat. the coolant temp. sensor triggers it at high temp. You'll hear it kick in. My 1.8L Suby's have rarely utilized this electric fan. Be careful looking around under the hood. Both fans are right there on the front and ready to hurt you. If your car is overheating and this secondary fan has not come on, then it's not working. But you should look deeper to find out why the overheating is occurring-this fan is for "normal" overheating;long steep climbs etc.
Mar 16, 2014 | 1995 Subaru Impreza
I have a Frigidaire gallery series fridge. The fan runs all the time and rarely turns off. The condenser kicks off and on normally and it's maintaining temperature but I don't know what it's causing the...
Hi Brandy,
As for your fans, the fans in the back of the unit, (bottom back of the unit, not inside) is called a condenser fan motor this only cools the compressor for the fridge. This fan only runs when the compressor is running. The other fan is in the freezer section and is a variable speed fans motor, this can do two different things with only one job. The fan itself can ramp up and down in speed to control air flow and temperature demand in the two sections. This can run a lot but should slow down when temperature is met or while in a defrost mode. So to sum up this answer, it is common to hear fans run in the newer unit over the older units. Believe it or not do save energy with just moving air over running the compressor all the time.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 15, 2013 | Refrigerators
Isuzu Trooper fan clutch not working as it should?
Its very possible the fan clutch has locked up and is now a direct connection from the fan to the water pump.
Depending on if it is controlled by temp or speed, it may not run at full speed when cold or at idle.
When the engine is cold and not running, a normal fan clutch would let you turn the fan blade without turning the pulley.
Oct 01, 2012 | 1991 Isuzu Trooper
Toshiba 62hm15a blows lamp after 3months
One possible reason I can think of here is I think this model had a quick start or quick on feature.
What will happen if it does is set will come on and work normally--when you turn it off and watch the lamp, it will dim down but NOT GO OUT--AFTER 3-5 MINUTES THE FAN WILL (LAMP FAN) go off.
It was a stupid feature, lamp is running 7/24 at about 40 percent brightness--idea was you did not have to wait the 10-15 seconds for brightness to come up and be normal when set is first turned on.
If this is your problem look in the main menu for a setting like that and disable or deselect it.
Set when cold will take longer to reach full brightness and when turned off lamp will go completely OFF and lamp fan will continue to run for a few minutes.
I hope this is your problem---PS if the set is real dusty inside it can cause issues but that is rare in this set.
May 25, 2012 | Toshiba TheaterWide 62HM94 62" Rear...
I keep getting warnings saying there is a problem with your cooling fan. please turn the computer off immediately. Please help.
Cooling fans can fail although this is relatively rare.
First of all you should check to see if thet fan is running at all. Normally you should be able to hear it running and you will also feel the warm air being expelled from the ventillation slots - these will be at the back or towards the back on one side of the machine and will be an obvious grille where the air is expelled.
If you can't hear the fan running or feel any air flow then the fan has almost certainly failed and will need to be replaced. This typically requires dismantling the laptop to a certain degree so you may not wish to tackle it yourself, although is you are competent with that sort of thing it's not too difficult if you can get hold af the service manual - you don't say what machine it is but if you want help with that please respond with a comment.
If the fan appears to be running it could be that the air vents are blocked with a build-up of dust. This can sometimes be removed with a vacuum cleaner - place a small nozzle over the vent grille to **** out any dust.
If the fan is running and vents are clear then you will have to dismantle the machine to check that the vanes on the heat sink for the main processor are not blocked, and that the processor is seated correctly on the heat sink. Once again this can be done by yourself if you want to tackle it, but you may wish to take it to a service agent for that sort of repair.
Feb 07, 2011 | Computers & Internet
I have a dell optiplex gx620 pc and the fan stopped what to do?
I am using a dell optiplex gx620 pc at this moment and the fan rarely runs admittedly as this is a small system i.e. very slim and I have the side cover off to accommodate a larger size graphics card and it keeps quite cool.
The fan should only run when it needs to cool down the possessor I rarely hear mine run.
Unless the computer overheating I wouldn’t worry but if you are you can clip off the side and test it with a battery.
Its easy to get at it's located at the bottom left of the motherboard connected to the board by a plug with a blue black red yellow multi cable pull off the cable and externally test the fan.
Sep 13, 2010 | Dell OptiPlex GX620 PC Desktop
98 camaro,radiator fans not working only off and on when I turn on my air conditionor. Replaced temp control senser,relays,thermostat. what next PLEASE HELP!
Although rare, it is possible that the fan motor is bad. I don't know if the connectors are the same or if there is only one connector for the fans. My point is try to switch the connectors and turn the a/c on. One fan runs off the coolant temperature sensor and the other off the a/c hen the compressor is running. It basically senses a load on the engine and engages the fan. The one that works has power to it so you know if it does not run the other fan, the problem is the fan. If you have the V6, it may just not be getting hot enough for the fan to kick on. If you have the 5.7L, I would definitely confirm the fan is good because those engines are designed to run hot and they get up to running temperature very quick. Please rate me on this answer.
Jun 07, 2010 | 1998 Chevrolet Camaro
I have a 2001 nissan sentra. My car fan is running and making loud noise. Also my temparture gage is going up but my car is not overheating.
small engine does take allot to overheat as long as the car stay in motions even though the cooling is not operating, if you were sitting in the heavy and stuck in traffic and the OAT is 98-100 degree with high humidity and running the AC, chances are the engine will over heat quickly. very rare the temp guage become faulty, I would to go ahead and repalce the temperature sensor which gives the guage the correct reading, if have high miles 75k or more replace thermostat which open and close when it reach proper tempature and thermostat switch which turn the cooling fan on and off. all three parts are fairly cheap to fix and replace. all three unit is very important to the engine cooling beside the oil.
Oct 21, 2009 | 2001 Cadillac DeVille
Compaq Presario fan problems
the fans on a computer tower run all the time to help keep the pc cool. this is normal in a tower pc of any brand
Dec 04, 2008 | Compaq Presario Fan
Computers & Internet Logo
44 people viewed this question
Clive
Clive
Alun Cox
