Question about Panasonic KX-TG5633B Phone
Answering machine not working
The answering system part of my phone suddently stopped working. It says the answering system is on, but it doesn't record anything. I have a recorded greeting, that is there when I hit the'check'button; but my greeting is not heard by the caller - only the electronic greeting is heard. Even when I turn the answering machine off - the caller still hears the electronic greeting telling them to record a message making them think they're leaving a message - But, no message is recorded.
3 Suggested Answers
SOURCE: Recording greeting message
having same issue
Posted on May 10, 2008
  • 38 Answers
SOURCE: How to change the answering maching message
Depending on how your automated attendant is programmed, you will need to either change certain prompts or certain Custom Service menu greetings. Without knowing how your system is configured, I can't be more detailed, sorry. However, we can fix this for you over the Internet with our remote support package...
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
  • 2460 Answers
SOURCE: Can you set the answering machine to answer with a
On page 42 or so of your manual, there is a Greeting Only option MENU 0 6 2, where you can adjust the message length or set the G.O. option.
Posted on Nov 07, 2009
0 characters
1 Points
I would like to change the answering machine message
Record a Personal Greeting
Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
Aug 21, 2013 | Panasonic KX-TGA101S Cordless Handset
GE 25922 voicemail
The GE 25922 doesn't have voicemail. Please consult the documentation for whatever answering machine or voicemail system you have connected to your phone line.
If you need further assistance then please feel free to repost your question, but be sure to specify the answering machine or voicemail system you're using.
Oct 21, 2012 | GE 25922 Cordless Phone
Answering machine will not work
Power off the device and plug it back in. If that doesn't help, check the manual to see if there is a setting you can change. Next try the manufacturer's website for a FAQ that addresses your situation. Finally request a replacement from the manufacturer, assuming it is still in warranty.
Dec 18, 2011 | Panasonic Phones
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
Cannot get the answering system to work M M Brown
If you are talking about an answering machine it may be similar to the problem I had with the wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first. This might resolve it for you.
Oct 16, 2010 | Uniden Cordless Phone
Will the answering stop working when the battery is dead in the handset
No,This wont happen.The answering in connected only to the base unit.Answering system and the battery of handset is no way related.
Even the battery is dead the anwering machine will work.
Thank you
Aug 07, 2010 | GE Cordless Phone & Answering Machine...
Phone system suddenly stopped working
I have a 2.4 GHz cordless phone and I misplaced the manual. The answering machine went off. I would like to know how to put my voice on the phone.
Thank you
Dec 04, 2007 | Uniden CLX485 Cordless Phone
Panasonic KX-TG5633B Phone Logo
18 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
