Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failure error Oxc18a0306
Replaced magenta cartridge (twice) continue to get 'Ink system failure" I took the following action: turned it off, removed all ink cartridges, waited 5 min, pluged unit in, re-installed cartridges, same error came up. Ihave done this 3 times.
  • 20 Answers
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
HP Photosmart C5180 - Ink System Failure. Error Oxc18a0306
Try updating your drivers first:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system has Failed. Error: Oxc18a0306. Please Help.
what is error oxc19a0027 on an HP FotoSamrt C7280 and how do you fix it. email copiersunlimited1@yahoo.com
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Ink cartridge
clean the contacts of the inkcartridge chip e.g. with spirit
or
Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shown correctly
May 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
2,099 people viewed this question
Ben Johnson
