Question about Dell Latitude C610 1.2GHz - 256MB - 20GB - CDRW (DELLC6101225620CDRW) PC Notebook
Keyboard problems The "zxcv" keys and the "m,./" keys don't work at times but at times they do.
  • 624 Answers
This is typical of a keyboard that is failing. Your laptop is probably still within its three year warranty so I would contact Dell tech support and talk to them about a repair. They will likely want you to run their diagnostic on the blue drivers & diagnostic CD that came with the laptop so you would save time by running that first. All you do is place the CD in the CD drive, turn the laptop on and hit the F12 button when prompted but before the Windows start screen appears. The CD is self booting so when you are prompted hit a key to boot from the CD and start the diagnostics program. Select the keyboard test, run it and document the results at the end. Let us know if you have any other questions and thanks in advance for rating this posting.
Posted on Apr 01, 2007
Started typing multiple letters when only one key is touched.
Sounds like a physical malfunction of the keyboard - in your position, I would replace it. You could try to take it apart (which is easy) but re-assembly can be tricky.
Jan 04, 2016 | SIIG JK-WR0612-S1 - Wireless Ultra Thin...
HP 2000-208CA Keyboard Some Keys Don't work
I had a similar problem after replacing a damaged keyboard, turned out that the ribbon cable kept pulling slightly from its socket each time i replaced the keyboard, try lifting the keyboard gently and check that the ribbon cable is fully inserted correctly.
Apr 06, 2013 | Computers & Internet
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Asking for a friend, their zxcv keys aren't working, any ideas?
The membrane has most likely been damaged through wear or liquid damage. He/she will need to purchase a new keyboard.
Any USB or PS2 type connection keyboard will do. They should be available at your local computer store.
However there is no harm in trying the keyboard in another computer to rule out the possibility of bad drivers.
Take care!
damnor01
Jul 19, 2011 | Compaq Keyboard
Zxcv keys not working
It is possible that something was spilled on the keyboard (like juice) and now they won't work anymore. In this case, if you have a normal keyboard you can open it up and clean it or take to a repair shop or just buy a new one. If you have a laptop it's a bit tricky because if you haven't done this before it's more difficult to open it and clean it. So if that's the case take it to a repair shop and they will clean it OR tell you what it's wrong with it.
I presumed there was something spilled on the keyboard. If that's 100% not the case you might want to provide more detail because I can't think of another reason for this to happen. Haven't found anything relevant on the internet either.
May 16, 2011 | Computers & Internet
The keyboard some keys no work, zxcv m,.- space
the keyboard is most likely defective and will need to be replaced. You should try removing it and reseating the connectors before buying a new one though just in case.
Mar 15, 2010 | HP Mini 1000 Netbook
The letters ZXCV does not show on monitor nor write to document. please can you help? dell inspiron 2200.
Reseat the Keyboard ,Dont try Yourself call Dell & be on the call so they will walk you through
Jan 09, 2010 | Dell Inspiron 2200 Notebook
When I type the letter "C", it prints ZXCV on the screen
It sounds like the electronic circuit of the keyboard may be failing but to be sure it isn't something simple like a small amount of fluid getting under the keys and acting like a wire to conduct the signal from one set of letters to another. I would remove the keyboard and using compressed air, clean the keyboard with short bursts. The take a Q-tip and alcholhol and run the q-tip under each key to clear away fluid, dirt and debris. If this fails, then I would recomment keyboard replacement.
Dec 02, 2009 | HP Pavilion zd7000 Notebook
When I type the letter "C", it prints ZXCV on the screen. Could the keyboard be going bad?
Yes it's the keyboard problem. Not only the letter C is the problem, but the first row has the problem. There's a part that needs to be replaced.
Contact the manufacturer and have them repair it for you.
Have a great day!
Oct 08, 2009 | HP Pavilion zd7000 Notebook
Computers & Internet Logo
400 people viewed this question
Clive
Clive
Alun Cox
