Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Can't start snowblower with electric start.
The pull cord broke off. but we were able to run the snowblower fine with the electric start. ran it for about an hour and a half. shut if off and now we can't restart it. What can we do? Husband and son are DONE with it. HELP
  • hkruz Mar 03, 2009
    Pull cord broke off TroyBilt snowblower. Used electric start, ran fine. Now cannot restart. Help!
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Posted on Jan 19, 2009
  • 211 Answers
Hi
Remove the starter and check:the starter housing,the armature,the end cover with brushes and springs,the wire terminal connections and the pinion gear.Charge the batery(something is wrong with the starter and the charging batery came loose.
best regards savumihai71
Posted on Dec 22, 2008
Snowblower starter won't work
Probably just a bad starter.
Oct 08, 2017 | Dryers
I have a Toro 8526 snowblower. Pull cord drags in cold weather- I have to use electric start-once started and warmed up, pull cord works fine-is this condensation you think?
Sounds like your recoil starter is dry. when it's cold it makes it a lot worse. I would shoot a little oil into the recoil. Even try a shot of WD40 and if that works use an oil can to shoot oil into all the moving parts
Dec 22, 2016 | Garden
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Pull starter won't pull
ALL-- Power Equipment-- needs to be inside & warm,
NOT in an outside shed
Have to warm it up inside-neighbors garage!
Feb 28, 2014 | Toro Power Max 726 OE Snowblower - 37771
The ground broke off of the electric starter of my troy-bilt storm 2480 snow blower. Is there a way to fix it other than buying the $230 dollar replacement part?
You could just connect it as usual but provide a wire with an alligator clip on one end and the other end connected to the bare ground wires in the outlet box whenever you need to start the snowblower. An alternative ground location that is often easier for homeowners to access is to connect it to a cold water copper pipe, the external, visible ground point near the electric service, water main, cable TV, telephone, etc. Some states permit iron gas lines to serve as ground too. Check with your wiring inspector or local electrician to see what is acceptable in your town. Whichever way you choose to access ground, add this wire without disconnecting any of the others.
Once you have it wired up, the procedure is pretty simple really - you would first connect the alligator clip end of the ground wire to an unpainted, solid part of the snowblower's engine, starter motor or frame. Then plug in the power cord the way you did before the ground was broke off (orient the cord / plug as if the ground were still present). Press and hold the start button as usual until it starts. Once running, remove the 120 volt power cord first - then disconnect the grounded alligator clip. The ground clip must always be first on - last off. This way, at no time is the snowblower ungrounded when it is connected to 120 volts.
Of course, some folks will say you don't have to have a ground connected. True, it will work / start without the ground wire - but you do give up a bit of safety by ignoring it. The ground is to protect people from electrical faults - its presence does NOT effect the ability of the starter to function. I wouldn't dream of spending $230 to replace the starter just because it is missing ground wire (because it is so easy to get around the problem with my simple little fix) but I would only start it w/o the grounded alligator clip wire if I had too. For maximum protection, you should be connecting the snowblower to a ground fault protected outlet when using the electric start regardless of whether or not you're using the ground wire alligator clip.
Jan 07, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Snowblower starting problems
It is still jammed disasewmble if necessary.
Dec 17, 2013 | Garden
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
How to start my snowblower model #247 886911
check gas and oil
put full thottle
full choke
prime 3 times
pull cord or electric start
repeat if doesnt start
Dec 25, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Has run fine. used for hour to hour and a half and all was good. quit for an hour. added fuel and ran again. but, within 10 minutes, it died and a little smoke came from area around the pull cord. ...
Do you have the correct Resistor plug in the saw? If the plug is correct and muffler is clear, air filter clean, my thoughts would be a clogged carburetor.
Jun 09, 2017 | Husqvarna Operator's Manual 365 372xp ...
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
1,968 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
