Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1000 shuts off on it's own
We have a new Cuisinart DCC-1000 that makes great coffee, but shuts off by itself. We do not use the auto-on or auto-off features. After we brew a pot in the morning, the machine shuts itself off an hour or two later...and always at different times. Any suggestions?
  • 8,596 Answers
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
Why does me Cuisinart coffee maker shut its self off immediately after brewing
You seem to have the AUTO OFF feature programmed to zero hours. You can set it up to 4 hours in 1-hour increments. Once you have set AUTO OFF to something greater than zero, you can
restart the timing cycle by cycling the on-off switch off then back on.
Jan 04, 2015 | Cuisinart DCC-1200 Coffee Maker
The coffee pot turns itself off immediately after brewing a pot of coffee.
The machine is designed to shut off after the brewing cycle after a period of time which you can manually set anywhere from 0-4 hours. Check your setting to make sure that it is set for a reasonable amount of time for you. We have the user manual at the link provided: DCC-1200 Manual. If you run into more issues with the auto off there might be a problem with the board in your machine. If that is the case you will have to call Cuisinart directly to get a repair auth for the machine.
Nov 01, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Nov 15, 2008 | Cuisinart Coffeemakers
See post on Cuisinart customer service. The tube can be purchased at Lowes. Clear vinyl 1/2" O.D., 3/8" I.D. The compression clamp will have to be replaced as well.
I used a 1/2" hose clamp available at any auto parts store.
Aug 19, 2008 | Cuisinart DCC-1200 Coffee Maker
How to use Cuisinart DCC-1200 Coffee Maker to make a pot of coffee
Just bought a DCC-1200 from Goodwill for 4.95. Looks brand new. Would heat up and sputter but nothing comming through to the pot. Removed botton with T-10 torx driver. Remove hose with check valve in it. TYou can squeeze the hose about an inch down and feel it to determine which hose its in. Pushed the valve out with a screw driver over a towl so if the little ball fell out I wouldnt loose it. There was a small wad of yelllow paper clogging the valve. Removed it. Reassembled and it works great.
Jul 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
1,549 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
