Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 Charging Question
I recently just bought a sidekick 3 from one of my close friends and he said the person that previously used the phone had problems with it concerning the battery or possibly the charging port but he was not completely sure. So i ordered a battery for it off ebay for about 10 dollars total and i put it in the sidekick and used a charger i had for a sidekick 2 in my room and the orange light came on and stayed on for maybe 15 minutes then turned off but when i tried to turn the sidekick on it didnt work.
The sidekick doesnt have the back cover but i ordered that also but hasnt arrived.
I have also tested a friends battery in my sidekick 3 with his back cover also and it turned on and worked completely fine.
Can u please tell me what might be wrong with my sidekick and how i might be able to fix it.
Thank You Very Much.
-Jared F.
    President:
  • 625 Answers
The sidekick has an issue with its charging port going bad. Do you get the orange light when you plug it in? Does nothing come on after it has been on the charger for awhile? Then more than likely it is bad.
It about 80 dollars to get fixed or you can do a workaround for about 30 dollars.
What you need to get is a charging cradle that has a spare battery charging slot. This will you allow to charge your battery seperate from the phone. I also recommend getting a second battery so one can be charging at all times.
Here are some links for the charger and the batteries:
Sidekick 3 Battery Charging Cradle
New Spare Sidekick 3 Battery for Sale
Hope that helps
Posted on Dec 21, 2008
  • 31 Answers
I can tell you the sidekick 3 will not operate properly with out a back cover. In fact, if you remove the rear cover while powered on, it will post a warning message on the screen.
Because you tested and successfully operated the phone with out complication with a back installed I fell confident you should have have any problem with the phone when your back cover arrives.
Good Luck
sponsored by Cell Phone Technicians
Posted on Dec 20, 2008
If my sidekick is refurbished and it charges but dont come on what can i do?
the Sidekick 3 has a charging issue that cropsup after awhile. The charge port gets broken and It will just not charge the battery. A good way to tellis if the orange light comes on but the phone never charges.
If you have a friend that has a sidekick 3 or sidekick ID, try their battery in your phone to see if it powers up.
Youcan get an external battery charger for the sidekick for about 25dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick wont turn on
that happened to me before.
all u have to do is take ur sim and battery out and then wait for 5 minutes and re enter them into ur phone...!
Oct 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick wont turn on
corbolicous1-
Is it a sidekick ID? If you bought if from t-mobile and it hasn't got wet or been dropped then call T-mobile CC. IT should still be under warranty. Do you have a friend that has a sidekick 3 or a sidekick ID that you can try the battery from(they are the same) What type of charging cradle, one witht the spare battery charging slot? Let me know....
Jul 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 charging problems
Ok, is the sidekick 3 brand new out of the box or new to you.
The sidekick 3 has an issue with the charging port being bad.
I would contact the person who you bought it from and get a refund.
The other option is to get an external battery charger and charge the battery that way
check the link below for those
Sidekick 3 external battery charger cradle
Jun 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Ayy
Is the orange light coming on but you have no power? If so, then it is probably not charging. The sidekick 3 charging port is notorious for going bad. The little contacts that send power to battery come loose.
Find a friend that has a sidekick 3 or sidekick ID and try out their battery. If it powers up, it is your charging port.
The easiest thing to do is to get a charging cradle that has a spare battery charging slot. They run about 25 dollars off off ebay and allows you to charge the battery seperate from the phone. A spare battery is good too as it allows you to have one charging at all times.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick Spare Batteries
Jun 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
If you can, try a friends battery, either from a sidekick ID or sidekick 3. The Sidekick ID seems to be having the same issue as the sidekick 3 whefre the charging port goes bad. The best worka round for that is to get a charginfg cradel that has a spare battery slot.
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
Sounds like you unit is not charging. The Sidekicks are notorious for that. If you have a friend that has a sidekick ID or Sidekick 3, see if you can try their battery to make sure you phone is working.
If not, your best option is to get an external charger that has a spare battery slot That way you can charge the battery outside the phone! They run about 25-30 dollars on ebay and since you have an extra battery you can have one charging all of the time!
Mar 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
162 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
