Question about Samsung HL-P5063W 50" Rear Projection HDTV
Lamp light blinks 3 times shuts down
Had set three yrs. Lamp went out . TV would come on with sound but no picture the shut down after lamp light blinked and reset 3 times. Then lamp and timer light comes on. Replaced bulb, same problem, replaced color wheel due to whining noise and replaced ballast. Reset bulb with Mute 1-8-2 ON and still same problem except this time no sound comes on.
What could be wrong. I checked and rechecked each step over and over again without success. problem is the same as when it went out at before replacing parts.
CLS
  • sweetkyman Dec 28, 2008
    if you find out the problem id love to know. i have replaced my buld 3 times in 4 years.. the last bulb i put in lasted 2 weeks ? im wondering if the fan motor isnt working? and causing the problem ? if so can it be fixed at home by a novice?
  • Anonymous Jan 10, 2009
    Lights blink, no signal...
    Novelist:
  • 159 Answers
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Posted on Apr 08, 2009
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
STANDBY INDICATOR LIGHT BLINKS 15 TIMES WHEN TV IS TURN ON NO PICTURE OR SOUND
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.
Dec 05, 2010 | Sony KDS-60A2000 60" HDTV
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Picture No Sound
First look for Bad Capacitors on [power supply board,if anyone of them is puffed up on top they are bad,Then if you do not have any bad caps How old is the Lamp in Set? if TV recycles 3 times for turn on and you have 2 greenlights on front and one red light---- lamp needs to be replaced.
Jun 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Tv not working after lamp replacement
CK Fan if it is going bad set will shut down.
Feb 06, 2009 | Televison & Video
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Nov 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
Samsung HL-P5063W 50" Rear Projection HDTV Logo
258 people viewed this question
Jerry Greenberg
Jerry Greenberg
