I push the power button and it just makes a clicking noise (like a relay fuse)for about 30 seconds and then stops. It does not even start to have a picture.
my tv was working this morning, dvr cable is still hooked upi have a 52' rca home theater"146280206"this is the number off the back of the tv please email as soon as possible with e mail iformation.pcude1@yahoo.com thank you penny.
Show your appreciation by commenting on my 32inch rca will not turn on:
Solution #2
posted on May 21, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I had a transistor on the board crack in half - I unplugged TV for a couple weeks to drain capacitors & reduce risk of a shock - Opened it up - slid board up so I could see it - it was a flat brown round one - obviously cracked - had to find it on-line at an electronics parts supplier - had to by pk of 10 - only ~15.00. Soldered in the new one - TV has worked for another 2 yrs & is going strong. Good luck. I think a lot of problems can be fixed yourself if you just look at the board & look for bad solder, loose components, or obvious burnt or cracked components.
Was this solution helpful? Show your Appreciation by rating it:
