Question about GE WBSR3140DW Top Load Washer
GE WBSR WASHER WATER OVERFLOWS
My washer wasn't spinning so we took it apart to see if one of the tubes was obstructed...my husband found that the belt had come off so he bought a new one and replaced it...now the washer is spinning, but when we added clothes to it the water overflowed into the kitchen. The tub is draining and spinning so we were able to get the water out, but it doesn't stop when you put water in.
  • mcmair2 Dec 20, 2008
    He did disconnect the water level sensor and forgot to reconnect it, but he reconnected it and the water still won't stop. The main program button is turning properly, but I don't think it is agitating. It is spinning correctly.
    Scholar:
  • 141 Answers
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Posted on Dec 20, 2008
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Washer machine over flow at start up
Hi There
I have this for to read and hope this gets you in the right direction. Let me know how it goes.
Thank you for writing to fix ya.
Dec 29, 2009 | GE WBSR3140DW Top Load Washer
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
It overflows water because it doesn't spin it out on the spin cycle
Water-inlet valve
Water-level switch
Aug 21, 2009 | Washing Machines
My washer will not spin while in permanent press or any load cycl
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Mar 29, 2009 | GE WBSR3140DW Top Load Washer
GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Feb 19, 2009 | GE WBSR3140DW Top Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Washer fills continuously until it has overflown
I found this answer on Repairclinic.com. Hope it helps...
Oct 22, 2007 | GE Hotpoint Super 3.2 cu. ft. Washer
ZWashing machine stops at spin cycle
I just had a similar problem with my GE washer, mod # WPRB9110D1WW.  I had 2 different GE service men come out - the 1st  one was no help, said to unplug the washer for 5 minutes to reset the electronic controls - worked 1 time doing this.  The 2nd service man came out, told him it would stick in the rinse cycle and not spin, also had short fills of water.  He immediately popped off the front of the washer (insert a putty knife in 2 locations at the top), and showed me there was a plugged up pressure switch tube (clear plastic) located on the lower left side of the tub; he pulled the tube off the connector to the switch, cleaned it out with a small screw driver, reattached it, and it has worked fine ever since then.  It took all of 5 minutes to fix it.  He suggested washing some rags with bleach every month or so, said the bleach kills the bacteria build up that causes the stopped up tube.  This service man told me, a lot off people replace the electronic control panel needlessly for this problem, and waste their money.  I don't know that this is you fix for your proble, but it's something easy to do.  Hope this helps!
Aug 07, 2007 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
133 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
