Question about Car Audio & Video
Lights don't work with toggle switch on consol
The wiring is intact, the switch is good, and thelights are good. There are three wires going to the switch, one of thrm is.48 volts D.C.. The other two are .01 and .20 volts D.C. respectfully. I nrrd to know how to makr thrm work.
    Problem Solver:
  • 5 Answers
If its a 12v dc system you need atleast 12v dc at the switch and you'll also need a good ground wire to bare metal.
Posted on Dec 20, 2008
How to hook up a two wire toggle switch to a 1987 Yamaha virago three wire key switch
you would need two 2 wire switch's as one wire feeds switch , one feeds ignition and one feeds starter to start on momentary
May 16, 2015 | Yamaha XV 535 Virago DX Motorcycles
Have a 97 honda. Just purchased. It has a toggle switch installed that works with original key ignition. That said... toggle controls whole electrical..everything works..except tail lights,and the dash...
So If I understand, you turn on toggle and then use key to engage starter? Do brake lights and turn lights work, just not the running lights? Or are all tail lights dead. If none work, juice is not getting to the headlamp switch. Best fix would be to replace the probably bad ignition switch and repair wiring back to original, but quick fix would be to run a second wire from toggle switched side to the headlamp switch +
Dec 18, 2014 | Cars & Trucks
What causes runing lights to go out all together?
Has to be in wire going to rear of car my guess if the front ones still work run new wire splice into front ones (back woods hick solution hehe
Jan 31, 2013 | 1997 Mitsubishi Galant
Center console park and drive lights replacement
did you check the dash light dimmer ! if yes the switch may be bad. check for a loose wire to dimmer switch also. good-day !
Dec 17, 2011 | Toyota Corolla Cars & Trucks
I have a 2005 Mercury Marquis but the brake lights won't go on. I have turn signals, but no brake lights. I don't think it is a fuse.
look under by your brake pedal, there is a switch that has two wires to it, make sure plug has not been knocked off, if it is intact, check to see that one of the two wires have power,
if you have power, fuses are ok, jump the two wires and check to see if your brake light are on!
if they now work, you need a brake switch,
if you do not have power then you need to check your fuses..
i have seen many times that the connector gets bumped and makes a poor connection
good luck and hope this helps
feel free to ask questions by responding to the thread
Jay
Jul 05, 2011 | 2005 Mercury Grand Marquis
I have a 94 ford probe, The radio works when it wants to.. but the prblem is the tail lights and dash lights went out about a week ago, Checked all fuses in car and under hood checked all light bulbs all...
You need to replace headlight switch - if fuses, bulbs, wiring looks good. Avoid the toggle switch idea, you'll be opening a whole new can of worms.
Mar 01, 2011 | 1994 Ford Probe
Rear brake lights not working
first check your fueses, if thats not it on the slinder part of the arm behind the dash "the break" arm. There is a toggel switch when you push the break the button will release causing the break lights to come on when you let off the breaks it will engage the toggle switch and turn off the break lights....if the toggle switch goes out they wont work also have some one stand behind the car and wiggle the wires of the toggle switch see if it has a bad connection before you replace the switch could be just corresion or the wires may have came loose..
Dec 22, 2010 | 1994 Geo Prizm
I have a 1985 Cheverolet pick-up. I have a cluster of under dash guages that I installed about ten years ago. Last week I replaced them with new ones. After doing so, My rea tail lights will not cut...
Sir,
It's probably the brake lights that are staying on, check again, if the brake lights are staying on the brake light switch needs to be replaced. The reason I believe it's the brake lights is that they will turn on even with the key off so make sure which lights are staying on.
Click these links for more info.
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 10, 2009 | Chevrolet S 10 Cars & Trucks
After market radio wires causes light issue with light switch
check your ground on the radio......... the feed from the lights will test as a ground and the radio will use this as a circuit and turn on the lights. been there done that what a nightmare
Oct 02, 2008 | 1996 Dodge Dakota
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
