Question about Koss KS4102 System
Speaker mode AV2 retained?
I just found out that, to have the Koss output to ONLY the two forward speakers in AV2, I had to perform a mode change to "STEREO". Will that mode change be retained when I return to AV2 even after using AV1 and DVD?
    Genius:
  • 1,074 Answers
No you will have to reprogram it over again maybe it will stay for, a while but not for long.good luck.
Posted on Apr 02, 2007
SOURCE:
STEREO HAS NO SOUND OUT OF SPEAKERS COMING FROM AMP
I suggest you begin by checking the integrity of the speakers and wiring. This is a fairly easy test to perform and I usually used a pp3 9 volt battery across each pair of speaker wires to ensure each speaker produces a similar amount of crackle and hiss as the wires are wiped across the battery terminals.
Once that test has been performed and found to be satisfactory it is time to connect the wires to the output of the device; radio or amp.
If there is no sound it will be because there is no output from the device. At this point before calling the repair shop it would be a good idea to read the instruction manual to ensure the stereo is being operated correctly.
Aug 10, 2015 | JVC Car Audio & Video
I have connected the audio optical cable from my TV, but I couldn't get the koss system to work. Are there any other settings need to be set? Which channel should i use to get the sound AV1 or AV2?
AV1 & AV2 are the Video Inputs from your external devices such as DVD Player, Freeview etc.
I presume you have something connected to your TV and want to get this sound from your TV to output through your Koss.
Their should be a menu to activate the Optical Input but I can't find the manual to advise the correct menu.
I'll keep looking for a manual so if you can't find the menu let me know and I'll see what I can do to guide you in the right direction.
Jul 25, 2011 | Koss KS5190 System
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Connecting 4 speakers
well some computers dont support 4 speakers.
Dec 13, 2007 | Acer Aspire™ T180 PC Desktop
Koss Ks4102 video problem
You have chosen the progressive scan option. In this option you will not get a composite video out to your TV using a single cable. you need to switch off this option by connecting the DVD player using three single cables namely Rr, Yy, Bb. this is possible only if you have this input option on your Tv. once you do this you will be able to see the display correctly and do the changes of switching off the progressive option. refer to the manual it is explained
Oct 25, 2007 | Koss KS4102 System
Audio output
you should be able to connect any pc to any home stereo device. you will need a special cable to connect them though. usually a local radio shack or circuit city type store will be able to help you. You will need a " Stereo Headphone to Stereo RCA " cable. ask someone at the store for one of these, explain what you are trying to do, and they will likely be able to help you as well. after you get this cable you can simply plug your computer into the back of the Speaker amplifier (usually called aux or line1) where there will be a red and white plug. set your amplifier to the Aux input and listen away.
Aug 13, 2007 | Koss C220 System
Koss KS3102 System
I had a similar problem. Believe it or not, I randomly switched which ports the speaker wires used to connect to the receiver and kept playing with it with music going until all the speakers were making noise.
Jan 30, 2007 | Koss KS3102 System
Woke up turned the system on and have no sound
i have no idea but it sounds like toast to me
Jan 02, 2007 | Koss KS2503 System
Koss KS4102 System Logo
78 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
