Water is leaking from the powder drawer of my Aquaius 1200. Im not certain what is causing this. It occurs at the begining of a cycle and lasts for about 30 seconds. After this the cycle continues as normal and all the clothes are clean. A lot of water leaks from the drawer when i use a normal cycle. However i dont have the problem when i use a quick wash. Any help would be gratefully recieved. Thanks.
I am experiencing the same problem with the same machine. Does the suggestion work?
Don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
exactly the same problem,tried cleaning draw and hose but still leaks just on first fill?????????
