Question about MyMusix PD-6070 MP3 Player
Headphone Malfunction Headphone plays only on left earphone. Wil work for days and then malfunctions. Could this be due to the earphone jack, or the headphones. Has happend to two sets of headphones.
    Scholar:
  • 141 Answers
It's probably the jack inside mp3 player who needs a little bit of solde on his contact.
open it and good luck
Posted on Dec 20, 2008
Sony stereo mhc-gx9900 audio doesnt come out of speaker thou all lights show its playing
There is a intermittent problem on the main board, or the headphone jack is dirty or worn contacts, buy electronic cleaner, spray into headphone jack or earphone jack, slide headphone jack in and out as you spray the contact cleaner, do this several times in a attempt to restore audio.
Apr 06, 2012 | Sony MHC-GX9900 Shelf System
My mp3 player does not play song while attach by headphone
Does it play on the mp3 but no sound comes out of the earphones? Also check the earphones to see if they work on other devices.
If the earphones are working well, then there might be a problem with the earphone jack of the mp3 player. Take to a technician for correction.
Aug 28, 2011 | Computers & Internet
Input jack on my hp541 kicker headphone's sound comes and goes. I have tried multiple cables, If I wiggle the cable around it works in one speaker sometimes both.
Hi hotrodjayrod,
If the symptoms remain the same after trying another headset, this kind of fault is caused by bad solder joints in the earphone jack itself of your unit. This is due to frequent inserting and pulling the headset plug. To resolve the issue, the earphone jack must be re-soldered. You have to open the back cover of your player and using a pointed soldering iron, re-solder the joints.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 20, 2011 | Kicker HP541 Headphones
My system is stuck on (c2) headphone and I can not any sound, unless I put the headphones in.
Hi Steve,
This is an indication of faulty earphone jack, this is where the headset directly hooked up. See sample picture below.
When the you hooked up the headset to this jack, internal switch will released the contact to cut the audio goes to the main speaker out of the unit. Once you pulled out the headset plug, the audio will back to the main output speaker out through this switch.
In your cased, there's a malfunction in the internal switch of the earphone jack that's you haven't sound output at the main speaker out.
You may spray contact cleaner directly to the earphone jack while inserting and pulling out the headset plug to clean the lead. If the symptom still persist, you must replaced it with new one to back the unit in normal operation again.
Hope I helped you.
Have a nice day!
May 17, 2011 | Sony DAV-S400 System
My earphones' audio isn't right. I have to twist the wires to get it fixed. Sometimes, it only has sounds on the left or on the right or nothing. What should I do?
You have fault in the wires that has been twisted and open/ shorted within losing the connectivity. The best thing is to get this replaced if you can do the work by yourself, you will have to buy the shielded twin core wires, one headphone stereo jack, open the earpiees carefully- it is tricky,so do it gently, solder the wires in accordance with the lead and shield on either sides and then connect to the stereo headphones. Hope this wil work out for you. Good day
Jul 05, 2010 | Sennheiser MX 360 Inearphones High...
Left side of earphone jack won't work. I have tried more than one headset.
Sounds like a bad headphone jack. Contact Apple at 1-800-APL-CARE.
-=/ Daft Tech /=-
Oct 22, 2009 | Apple iPod classic MP3 Player
2 sets of headphones will play only on left earphone.
Dirt inside of the headphone jack can be the culprit. If you have canned air, you can blow it out, or twist the headphone connector inside the jack to clean the contacts.
Dec 20, 2008 | MyMusix PD-6070 MP3 Player
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
MyMusix PD-6070 MP3 Player Logo
67 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
