Question about Lexmark P4350 All-In-One InkJet Printer
Appears in my printer and does not let me print and it says cosul
Error 1203 what does it mean
  • 781 Answers
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. The procedures below will help you to resolve this issue
for troubleshooting procedure click on the link below
http://support.lexmark.com/perl/support/support.cgi
post back with your findings!
Posted on Dec 20, 2008
What is error #1203?
MY PRINTER WAS PRINTING AND ERROR #1203 JUST CAME UP AND IT STOP PRINTING.
Aug 01, 2012 | Dell 946 All-In-One InkJet Printer
The printer read Cartridte error 1203 I am reading the manuel but I do not understand how to fix it to print. I do not have it connected to the computer I just want to make copies.
Are you using Dell Series 9 ink cartridges?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Rick
May 30, 2011 | Dell 926 All-In-One InkJet Printer
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Error #1203
The error indicates either a communication failure between the cartridges and the printer or by a short in one of the cartridges. Here's an article on Troubleshooting a 1203 Error Message on the Lexmark X5400 Series. Just click on this link: http://bit.ly/aDUAjM. Follow the instructions on the page. However, if the problem continues, I strongly suggest you contact Lexmark technical support for assistance. Thanks.
Aug 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Error #1203
There´s is cleaning issue try to use alcohol to clean the electronic contacts in the head printing slots
Aug 11, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Error 1203 means that there is no cartridge attached to the printer head. However, there are some cases when this error message appears because the cartridge is not attached properly to the printer. If this happens, the printer will not be able to identify the presence of the cartridge and thus encounter an error.
http://www.fixya.com/support/t5901483-printer_says_cartridge_error_error
Aug 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
Error 1203 is a very interesting cartridge error. It means your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Be sure not to leave any debris of klennex on those holder contact panel.
Hope this helps and please feel free to rate me
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Lexmark X5470 software rejects generic ink cartridges
Yes this may be the trick for it.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jul 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
