Question about Nitro BMW-482 Car Audio Amplifier
The amp wont come on
The amp just stopped working the protection light wont even come on i hooked another amp up to c if it was the wireing and tha new amp came on i checked the fuse and its good
  • 62 Answers
Sorry to have to tell u this but you blew your amp or just the channels this happens when you dont have the ohm rite for amp and speakers
Posted on Dec 20, 2008
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
Why is the red light that says protect on? my amp turns on but it dosent work, i have a sup hooked up & it dosent work. the red light that says protect is on.
first thing check all ground and power wires and make sure ur rca wire make sure it isnt cut in anyway. after that unplug ur sub and unplug the negative wire from ur amp, while its out check the fuses on the amp if all is well put all fuses back if not get new. then plug the negative wire back in if protect goes off check for heat and if no heat inspect the wires from speaker out put all the way to the sub, look for any wire touching another this is were most problems are even the smallest wire can trip a protect. if u still cant find the problem. an amplifier specialist is in order.if its trashed go on ebay and buy a powerbass there goin cheap right now. hope i could help
Oct 12, 2010 | Lanzar VIBE266 Car Audio Amplifier
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Sony xplod amp won't work it stopped for no reason
try hooking the amp up with 3 wires, the red power wire, the black ground wire, and the remote wire, do not hook up the speakers at this time
Apr 25, 2010 | Car Audio & Video
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
Random Protection mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Clipping means you have exceeded capacity. .A thumbs up would be greatly appreciated if this answer is helpful to you. random-protection-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Jun 01, 2009 | Nitro BMW-482 Car Audio Amplifier
When the red protection light comes on wat does that mean?? amp plays for 5 secs and tha stop while red is on, and my cars dome light dims at the same time
If the red light is coming on It mean their is a grounding problem. Also check if the power and ground wire is not cut or broken.
Feb 28, 2009 | Sony XM-1252GTR Car Audio Amplifier
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Nitro BMW-482 Car Audio Amplifier Logo
117 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
