Question about Canon PIXMA MP760 All-In-One InkJet Printer
Canon MP760 black ink dull and has stripes
Hadn't printed photos in awhile, but when I went to do some the black is dull and full of lines. Using all Canon ink (bought all new to see if it helped). Ran head alignment, print head cleaning, deep head cleaning, roller cleaning - nothing helps the dullness, though I did get the lines to disappear for a couple photos. Help! I scrapbook and I need to be able to print nice photos.
  • Canon Master
  • 1,997 Answers
Take the cartridges out and also the printhead and set the nozzle of the printhead on a 5-sheet pile of kitchen paper that was make wet in the middle with some lukewarm demineralized water ( water for an iron )there is not much necessary if there are clogged nozzles deep inside the printhead buy cartridge flush different methode for printers to find
How To EASILY Unclog Ink Jet Print Heads
Posted on Aug 26, 2017
5 Suggested Answers
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
SOURCE: Canon MX 700. I cannot get print alignment. I am
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Posted on Sep 17, 2009
proartya8765
  • 581 Answers
SOURCE: canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Posted on Jan 25, 2010
SOURCE: Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
Posted on Oct 26, 2010
All my ink cartridges are full, yet anything that needs black ink that is sent from the computer doesn't work. It feeds through and prints everything else but black even with new full cartridges. It copies...
You might try changing preferences in control panel. The defualt for most photo printers is color since that is the most used feature (and sells the most expensive ink!). I finally bought an HP 1000 to use for everyday printing of documents and business items becuase it only needed black and white ink.
Mar 21, 2011 | Canon MP610 Photo All-In-One Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Not understanding why there's two black ink cartridges
One tank is reserved for colour printing and the other one is for grayscale printing ( Black and white). Watch out as when you run out of ink and you keep trying to print a document with empty tank cartridge it will cause your print head to go bad. The cost of a new canon print head is the same as the cost of a new printer. Canon over priced the print head.
Nov 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Dull pictures ,new ink ,deep cleaning done ,ink heads cleaned
Are you using photo paper to print your photos? If you print photos using regular paper, the ink will spread out in the paper fibers of non photo paper and make the photos appear dull. I would try using paper made to print photos and see if that helps
Nov 07, 2008 | Office Equipment & Supplies
Ink not mixing properly, Magenta is taking over
return p/head and get a new one.it may b contacts in machine
Jan 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
112 people viewed this question
Clive
Clive
old marine
old marine
