Question about The Learning Company Jay Jay the Jet Plane: Sky Heroes to the Rescue (381551) for Mac, PC
Jay Jay the Jet Plane Sky Heroes to the Rescue CD Rom
Have tried using in Win98se and XP. Installs fine but when running in 98SE get error after name login page at which it quits: Director player error unable to open file "J:\Source Files\JSHR - Title.dxr" because it is already opened by another user". In Xp same problem but error is that the file"JSHR- Title.dxr" is not a director file. System requirements are met in terms of space and memory etc.
3 Suggested Answers
  • 85 Answers
SOURCE: Sky Heroes to the Rescue, problem...please help!
Hello Iluvfrnch, 1. Is the oruduct compatible with Windows Xp. Check the Box ,use with... 2. Load on another xp machine same thing? 3. Try using the compatibility software program in Xp and see if this solves your problem/ 4. Does disk have a scrach which could stop it from working?
Posted on Apr 20, 2008
SOURCE: an error message with error code:92
sometimes, this is happens when your cd drive has a weak lens or the disc you are using is faulty....
check the disc..... try to create an image of the disc using another powerful writer .... if the image creation is successful, then use the image by mounting on your machine instead of the disc....
Posted on May 27, 2009
Asus
Dear Mr. Yaseen; To install windows XP SP2, you will need a disk that self installs the windows. You will be asked very few questions. Now, who said that the computer does not see your drice? In order that we can check that we will need a Rescue Floppy Disk. When you bought the computer you were given two (2) CD/DVD, one contains the OS and the other the drivers. If the drive C is corrupt beyond repair, you will need the Rescue Floppy Drive, which open the way to MSDOS, upon which Windows XP SP2 is based. Remove all CD/DVD from the computer and insert the Rescue Floppy Diskette. It should start immediately. It will ask you one question, if you want to have CD/DVD help and you say yes. The rest will happen automatically and a new drive named "A" will be established: There is no drive "B" in normal windows; drive C is usually the "windows XP SP2" drive; drive D can be the C
Jun 23, 2009 | ASUS K8V-MX Motherboard
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
Apr 17, 2008 | The Learning Company Jay Jay the Jet...
Connect printer
XP and Win2000 are the same NT platform and are different from Win98SE and if you have the correct drivers installed for each then a single USB cable is sufficient as long as the printer is pointed to that port/device.
Mar 27, 2008 | HP DeskJet 722c InkJet Printer
Unable to boot, I can't installed WIN98
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | Compaq Armada E500 Notebook
Missing "imagehlp.dll" error on installation
Uninstalling other makers software may remove a system file which prevents installation of Coolpix drivers from the Nikon View v5.1 CD on Windows 98SE systems. It has been reported that, when connecting a Coolpix camera to a Windows 98SE machine, the hardware wizard will not recognize the appropriate driver; this setup fails because the file "IMAGEHLP.DLL" is missing from the system. Installation will stop with an error message which mentions this file. This problem may be caused by the earlier removal of another makers software from the operating system. To solve the problem, first disconnect the camera then follow these instructions to copy the appropriate file from the Win98SE CD back to the correct directory on your computer: Place the Win98SE CDROM in the CD-ROM drive. From the Start Menu select Run, type in SFC.EXE. Select "Extract a single file". Type in IMAGEHLP.DLL to the field provided. Click start. When the next dialogue box appears click "skip". This dialog box appears: Where e:\WIN98\ should be the Win98SE CD-ROM (your CD-ROM drive may use another letter other than "e"). Copy the file to the same destination shown and a screen will appear showing that "File has been successfully extracted". Next, remove the Win98SE CD-ROM from the CD-ROM drive and replace the Nikon View 5 CD in the CD-ROM drive. Reconnect the camera. The hardware wizard should automatically detect the camera and install the driver from the Nikon View 5 CD.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
The Learning Company Jay Jay the Jet Plane: Sky Heroes to the Rescue (381551) for Mac, PC Logo
64 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
