Question about Gateway T-1625 Notebook
Gateway T-1625 Laptop won't boot up at all
When I press the power button, the fan come on and the hard drive sounds as though it is activating. The system does not begin the posting process, as the LCD does not come on at all and there are no beeps. The system locks up at that point. The power button pilot light does not come on, but the 5 blue icons below the mouse pad come on and stay lit. The laptop just sits there with the 5 icons lit and the fan running. Holding in the power switch will not shut the unit off. I have to either remove the battery or disconnect the power cord to shut the unit off. The behavior is the same whether I power up under battery or charger cord. I tried hooking up to an external monitor, but no image appears. I removed and reinstalled the hard drive and memory sticks.
Is my motherboard dead?
  • stanhirsh Dec 21, 2008
    I didn't detect any hot spots, so I went ahead and ordered a replacement motherboard. Thanks for your diagnosis.
  • 62 Answers
It sounds like a motherboard issue. The fan spinning and the LED lights are running off of battery power. This indicates that power is getting to the system. You should look into replacing the motherboard at this point. Before you replace the motherboard feel your system to see if there are any really hot spots that would indicate overheating. If not proceed with the replacement. If so, let me know where the hot spot is.
Regards
Posted on Dec 20, 2008
2 Suggested Answers
  • 10406 Answers
SOURCE: Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Posted on Sep 10, 2009
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
I dropped my notebook about 5 feet about and when i booted the message was operating system failed.
First thing to do is determine the health of the hard drive. Enter the laptops setup on boot and see if the BIOS has a hard drive test utility. When you boot the laptop, look at the screen and find the function key (F10, F2, F12) that you will need to press to enter the BIOS. After that, look through the menus related to the hard drive and see if a test is in there.
Oct 27, 2010 | Gateway T-1625 Notebook
Good day. I have a Gateway m-1625 (reconditioned). About 5 months ago it started to give problems when booting up. When powered on the hard drive would be engaged & then it would shut off. After...
check the BIOS version, if there is an update for it on the gateway site apply it. a checksum error in CMOS BIOS cannot be overcome and you will always have to deal with this issue if no bios updates are available. There is a slim chance that you can revert back to an earlier version.
Mar 07, 2017 | Gateway M-1625 Notebook
Gateway M285-E, powers up, but no video on screen.
its the video chip desoldering itself. The cpu is thermally monitored, the video chip is not. HP addressed this and updated thier warranties based on this. The updated bios keeps the fan idling slowly rather than turning it off. I have repaired a few of these motherboards by re-heating the video chip, then reseating the bga underneath.
Nov 25, 2009 | Gateway M285-E Notebook
Gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
Nov 06, 2009 | Gateway M-1625 Notebook
Sep 10, 2009 | Gateway T-1625 Notebook
Gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Jun 24, 2009 | Gateway T-1625 Notebook
Gateway m 1625 operating system not found and its overheating
This means either the operating system on your hard drive has become corrupt and you will need to reinstall your operating system or, more likely, your hard drive has failed and you will need to replace the hard drive and the operating system.
As for your heat issue, use a can of compressed air and blow out all the vents on your laptop. This should help the heat issue; note that it is common for the laptop to feel hot as it is dissipating the heat from inside.
Thanks and please take a moment to give this solution a thumbs up rating with a solved solution as I answered your questions. Thanks.!
Apr 05, 2009 | Gateway T-1625 Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Gateway T-1625 Notebook Logo
727 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
