Question about Euro-Pro Shark 60 - 384
Upper Thread Breaks!!!
While sewing, my machine makes two loud clicks and then my upper thread breaks. I have tried fixing the tension, but do not know what else to do. This happens almost immediately when I start sewing.
    Genius:
  • 1,074 Answers
If you have not oiled your machine then it is best you do so, the machine is dry.or make checks on your bobin case it could be bend or needs to be ajdust.or worn out.good luck.
Posted on Apr 02, 2007
Hi, here are some reasons why the thread is breaking :-)
  • Threading is not correct.
  • Thread has a knot in it.
  • Thread tension is too tight.
  • Needle is bent or blunt or has a sharp eye.
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Hope this helps.
    Posted on Jan 14, 2009
    Why does top thread keep breaking?
    Sounds like your tensions, both upper and lower are out of whack. Easily fixed if so...google a vidyfor your make/model machine on adjusting both upper and lower tensions.
    Jun 18, 2017 | Sewing Machines
    My pfaff 1475 CD thread is loopy on bottom and breaks on top.
    Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
    A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
    Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
    Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
    Understanding Thread Tension Threads
    Sewing Machine Tension
    Apr 12, 2017 | PfaFF Sewing Machines
    My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
    Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
    Sewing Machine Thread Keeps Breaking
    NMSU Checklist of Common Machine Troubles
    Why Does My Thread Keep Breaking While Sew
    Apr 03, 2016 | Sewing Machines
    So when I start sewing it works for a few seconds then my top thread breaks and or wraps its self around the black casing the bobbin sits in. What am I doing wrong?
    Be sure to RAISE the presser foot BEFORE threading the upper thread. This releases the tension disk so the thread can seat properly. If upper thread is breaking soon after beginning to sew, it usually is because the upper tension is too tight. Try loosening it and re-testing. The upper and lower threads should meet in the middle of the fabric.
    Sep 21, 2015 | Singer Pixie Plus Sewing Machine
    Brother pc 8500 upper thread breaks
    Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
    Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
    Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
    Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
    It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
    But the mechanism that produces the tension can wear out or break and need replacement.
    Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
    I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
    My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
    Nov 17, 2011 | Sewing Machines
    Singer 15 thread breaks and doesn't sew
    if the upper needle thread is breaking adjust the thread tensioner if the bobbin thread is breaking adjust the bobbin tension screw on the bobbin case
    Feb 16, 2009 | Singer 3343 Mechanical Sewing Machine
    Euro-Pro Shark 60 - 384 Logo
    395 people viewed this question
    Top Euro-Pro Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
