Question about Hitachi 50UX57B 50" Rear Projection Television
STK392-110 Upgrade to STK392-150
Which Resistors do I change and to what Ohm?
Thanks,
MIKE
  • MIKE Hernandez Dec 20, 2008
    Thanks I was doing searching on here but did not find and answer. Thanks alot I just order some Now.
    Thanks Again,
    MIKE
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, should be none. The resistor should not be upgraded unlike the STKs. Technically, the ohmage/resistance values should still be the same. If you change to a higher wattage, then, what is improved is the heating capacity, meaning it will be more tolerant to the heat but the resistance value should still be the same.
The STK upgrade is actually more to improved heat handling/transfer capacity of the STK ICs. The technically correct description is high power used in low capacity hence will not heat as much as the originally installed.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
  • Louie  Role
    Louie Role Dec 20, 2008
    Glad to be of assistance and appreciate the rating too.
3 blinks problem with a TX42PT10F
hello the resistors should be in front of the chips when you test them make sure you desolder 1 end so you get a proper reading on the meter good luck
regards
shaun
Jan 15, 2010 | Panasonic PT-47XD64 47" Rear Projection...
I just replaced the convergence board on my JVC AV-56WP74, but the red still won't line up. Are there other parts that should be changed?
you also need to check and replace low value resistors in that circiut.they are all 1 watt,usually they get discolored when stressed.R842 2.2 ohm,R854 and R846 1.5 ohm,R850 2.2 ohm,R858 3.3 ohm,R862 1.8 ohm.they must be the exact value available in MD from surburban electronics.please note stk392-110 upgrade to stk392-150 for future referance.ONCE AGAIN CHECK ALL LOW VALUE RESISTORS
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
(6) 1.8 ohm 1watt metal film resistors for R7711, R7716, R7721, R7726, R7731 and R7736 yes the STK 392-150 will work fine.
Sep 24, 2008 | Toshiba 57H82 57" Rear Projection...
Detailed problem per your response
The problem is that the ICs may have been blown because the resistors were bad. Just as a double check before you replace anything else. Please confirm that the STKs are STK392-110. Also, replaceing them with STK392-150 is a valid upgrade, I'm not sure about the 180s, but I'll check. Both the STKs and the resistors need to be changed at the same time.
The hour glass view you reported: Was the bowing on the top and bottom or on the sides?
Thanks,
Dan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture looks like it is in 3D
Yes you need to replace both convergence ICs. They are both STK392-150 you will also need to replace the 6 feed resistors. You will need ( two ) 1.8 ohm 1watt metal film resistors.
( one) 3.3 ohm 1watt, ( 0ne) 2.7 ohm 1watt, ( one) 4.7 ohm 1 watt, and ( one ) 2.2 ohm 1watt . The resistors are all 1 watt metal film resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures, plus free tech support.
http://servicemanuals.vstore.ca/
Jul 30, 2008 | Hitachi 46F500 46" Rear Projection...
Would you have a list of the different resistiors???
270 Ohm 1/2watt
27K Ohm 1/16 watt
3.3K Ohm 1/8watt
3.9 Ohm 2 watt
150 Ohm 2watt
Jun 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Hitachi 61udx10b
Check the resistors near the Ics especially the 3.9 ohm 1 watt resistors often one or two will be open then when you install the higher wattage Ics which run cooler you can actually wipe out all the convergence resistors which are 3.9 2.7 and 4.7 ohm 1 watt resistors
May 20, 2008 | Televison & Video
Ic question
No change in resistors is necessary. The -150 can handle more power but will only handle that which is presented. I'm assuming that you are talking about the convergence STKs.
Dan
Mar 19, 2008 | Televison & Video
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
108 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
