Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Water does not drain
Design 2000 whirpool washer, water does not drain. the washer works untill the moment it supposed to drain before the rinse. it just stops.
  • j ball Dec 23, 2008
    thank you! it was a lid switch.
  • 179 Answers
Is your pump clogged if not check the lid switch
Posted on Dec 20, 2008
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
Whirpool gold washing machine(top load).Seeing alot of water,so i took the rinse/drain hose off the back to make sure it wasnt cloged.I then kept it of but started a normal wash and as soon as the water...
Sorry to read about your problem, I hope this helps you out.
no it is not normal, i suggest you contact a service company. A repair will cost alot less than a new washer...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water doesnt pump out to start rinse cycle
Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
Jul 05, 2009 | Washing Machines
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Bleach is spilling directly on to clothes
I have the same problem and here is the reason and the solution. When you add bleach it sits in the dispenser until the rinse cycle. During the rinse cycle the machine pours a lot of water through the dispenser. The bleach is diluted and washed out with all this water into the tumbler and you clothes are rinsed with bleach. Sometimes when this rinse happens, the water does not completely drain from the bleach dispense. It sits in there. If this happens, the next time you add bleach, there is too much liquid in the dispenser and it leaks out onto your clothes.
Solution: Before you add bleach, take the whole dispenser out and see if there is a lot of water still standing in the bleach dispenser section. If there is a lot of water, spill it out into a sink. Then fill the dispenser with your bleach and it will all work out the way it should. I was having your same problem until I discovered this. I have never had the problem since.
Let's give a toast to Bright Whites!!
Nov 07, 2007 | Washing Machines
Washing Machines Logo
194 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
