Question about Kenmore 15322 / 15324 / 15329 Built-in Dishwasher
There is an accumulation of water in the machine after complete cycle
Water is not completely draining after the machine completes its cycle. There is about 2 inch water remaining at the bottom of the machine
  • 148 Answers
SOURCE: my dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
Posted on Dec 21, 2007
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: My dishwasher will not drain completely
I had a similar thing with ours. Found out the drainage pipe that goes from the dishwasher to the pipes under the sink was blocked. Take hold of the pipe that geos under your sink from the dishwasher (usually a flexible pipe) and give it a shake and a bang a few times. Also check the filter inside your dishwasher, take it all out and give it a good wash. Look inside the cavity where the filter came out of and make sure no food / fat or other gunk is inside that. I also found those dishwasher cleaner things work very well at unblocking. Buy from a supermarket and you put it in the dishwasher with no dishes. Ours worked like brand new after I did all of this. Good Luck.
Posted on Feb 24, 2008
SOURCE: dishwasher will not drain
I have had that probem and the issue is food idems the size of beans or peas make it through the filter system and plug up the drain. Take out both the round and flat filter. The water drains through a row of ridges. Take a probe (fork, toothpick, ...) and clean out between those ridges. I can almost guarentee you will be pulling stuff out. It isn't necessarily visable, you have to probe down the drain a little ways. Let me know if this works.
Posted on Apr 04, 2009
  • 254 Answers
SOURCE: Water is not draining completely
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Posted on Jan 31, 2010
Daniel S
  • 4323 Answers
SOURCE: My dishwasher is not draining
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Also check this video for details---
Hope this helps... Please post back for any further assistance.
Posted on Mar 27, 2011
0 characters
1 Points
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Blinking complete light on a 66513292K015--won't go off and dishwasher won't complete cycle
possible fuse blown on pump which drains water out ? so program can't complete as water still in machine ?
Dec 23, 2013 | Kenmore 24 in. 17482 / 17484 / 17489...
Will not complete cycle
check if kitchen sink downpipe is clogged
Jul 06, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
After dishwasher completes cycle, it starts again. It will keep going unless we stop it.
If the cycle does not stop that is usually because of a faulty water level sensor. The floater that controls the water level in your appliance.The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely. Check if sensor is stuck or if switch is faulty.Some machine may use a membrane switch instead of a floater.
Mar 27, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Draining after completion of cycle
Miele dishwashers are typical not to drain all of the water. It is the way the siphoning system is designed. You will always have a bit of standing water after cycle completion but should not be above the bottom filter. You can manually drain the dishwasher by selecting any cycle and letting it run for 30 seconds and then turn the dishwasher off. Hope this helps
Sep 14, 2009 | Dishwashers
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher will not go through complete cycle it will not take water away
most washing machines nowadays have a electrically operated switch that will open to either drain or let in water if ur machine does not drain the water the machine will not go ahead in completing its cycle as the sensors sense that there is water in the drum so unless the water drains u will have this problem. Check for a click sound when the machine reaches a point to drain if that doesn't happen then it is this drain switch that isn't working
Jul 01, 2009 | Electrolux Dishwashers
Whirlpool dishwasher is not fully draining after cycle complete
Apr 07, 2009 | Dishwashers
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Jul 03, 2008 | Maytag Dishwashers
Kenmore 15322 / 15324 / 15329 Built-in Dishwasher Logo
32 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
