Question about Amana ALG331RAW Gas Dryer
Dryer runs way too hot. can't touch clothes
The dryer runs too hot
  • 71 Answers
Go outside and check the vent outlet. is air blowing out. if not clean vent, make sure vent hose is not kinked.
Posted on Dec 20, 2008
  • 10 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
  • 254 Answers
SOURCE: our dryer is a model # fer641fso. it is notgetting
u have a clogged vent,,, undo vent to dryer run a load if heats faster then replace dryer vent, and clean out ur ducting with a leaf blower blow that ducting lint outside.
Posted on Feb 03, 2010
  • 12 Answers
If your element is operating and drawing about 20 amps when on, your problem may be the thermostat (temperature dial) or the moisture sensor (if applicable).  My dryer has 2 heating elements.
Posted on Oct 15, 2007
jonniewalker
  • 1031 Answers
SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Posted on Feb 21, 2009
  • 8404 Answers
SOURCE: The dryer is not drying the clothes. It takes two
I suspect your exhaust is clogged. Check it thoroughly! This could be a fire hazard. Check the lint filter, the entire length of the hose and the flap on the outside vent. If your hose is plastic, please have it replaced with a new aluminum exhaust.
Posted on Sep 25, 2009
The heat coming out of ny dryer is to hot , the duct is way to hot to touch .model # yrel3613b(maybe 8)w2 thank-you
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Roper Dryers
The tumble dryer side of things is getting so hot i cant touch the clothes, obviously not supposed to be like that. is there a filter or vent that could be blocked
heatman101
Aug 06, 2011 | Hotpoint Aquarius WD63 Front Load...
When the dryer is running top of dryer where controls is hot to the touch
heatman101
Jul 29, 2011 | Hotpoint NVL333EY Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Cloths too hot
turn the heat setting down clown
Jan 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Amana ALG331RAW Gas Dryer Logo
707 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
