Question about Weiser Lock Powerbolt 1000 Lock
Dead-bolt in power bolt won't move
I've had my power-bolt for about 3 years, and very happy with it. Suddenly the dead-bolt just won't move. Makes a noise and moves about 3 mm in or out. Replaced the batteries (2x) to no avail. Is it just worn out??
It doesn't get used more than 2x per day.
  • D200user Feb 24, 2009
    Mine does the same. I replaced the batteries a couple of times. The small motor inside with a worm gear that runs on another regular gear moves but the bolt itself does not. I will have to try and get warranty on this if possible but I can't find my receipt. My local Home Hardware here in PEI, Canada says they have to send it out for store credit, if under warranty, and I would have to buy another then if the credit comes thru I will get a refund. I would love to tear it apart and find where things are not working but that would void my warranty for sure. If you get yours fixed post a reply.
    thanks
    Brian in PEI , Canada
The problem is with the small o-ring that is located on the main gear which is located under the sealed housing on the electronics board.
You need be carefull not to loose any of the small parts.
First you must remove the assembly that is located on the inside of your door. That will be the part with the electronics and batteries. Then place that part on a table with the knob facing the table. You will see 4 very small screws. Remove them. Just above the top screws that you just removed you will see a plastic retainer with 2 gears under it. It is right next to the the motor and worm gear. Holding that retainer down are 2 washer clips. Using a small very thin screw driver, CARFULLY remove those clips. The retainer will slip off and you can remove the asembly wear the knob is located. You will see a large flat gear that is attached to the knob shaft. Remove that gear by twisting the knob as you pull the gear. After the gear is removed, turn it over and you will see a black O-ring in the center. Use your small screw driver to pry it out. That ring is warn and you will need to replace it. You should be able to get it at your locale hardware store.
Put everything back in reverse order. Add a very small amount grease to the gears and you will be back in business. (((Remember to use a grease that will not harm the plastic parts)))
Posted on Mar 18, 2009
I had the same problem about 2 months ago. Contacted Weiser Canada via their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). Once i explained the situation, they didn't hesitate to send me a new set of "guts" for the lock (electronics board, etc.) Strikes me that this is a known design flaw, since there was no hassle with the replacement part. Hope this helps,
Cheers,
Posted on Jun 11, 2009
I used the solution of replacing the O-ring as described above. This made the unit tighter. Along with the O-ring, I removed the dead-bolt assembly and liberally sprayed it with WD-40 to clean out the years of dirt/debris. The dead-bolt slides freely as well. The unit works like new again.
One thing to note, this is my 3rd powerboard and when I disassembled each unit, I found that the 4 screws on the back of the powerboard (door facing side) all had broken screw retainers. I am not sure why they are broken as the units have not been disassembled prior. The plastic was brittle and disintegrated when removing the screws.
BTW, Weiser is sending me out a new replacement board, so I had nothing to lose. Now I have a new powerboard to replace the unit when it fails for good.
Posted on Sep 01, 2009
Denise
If you got the lock fixed, good for you. If not one solution is to remove it. I would be happy to buy it and try to fix it if your price is very low.
vjohnson@arizona.edu
Posted on Apr 08, 2009
  • Vern Johnson
    Vern Johnson Apr 24, 2009
    I have just obtained several new electronic units for the weiser powerbolt 1000. I will by happy to sell you a new unit to replace the one you are struggling with.
While typing text my cursor jumps back 2-3 lines
The keyboard speed maybe set too low for your typing skills, try increasing the keyboard speed.
Open the Control Panel - Keyboard - Speed tab and move the speed slider to the max speed.
Apr 16, 2013 | Computers & Internet
My 2005 nissan altima won't crank or turnover. It justs makes this clicking noise. Can you help me?
The click is most likely the starter solenoid you hear
Should be a familiar sound you've heard may times
on other cars
I would guess you know how old the battery is?
If it is original,it is 8 years old & dead,if so, replace it
If it is only 3 years old ,check the voltage with a meter
Next the solenoid could be working as you hear it,but
it's contacts are burnt,it can be replaced
You remove the starter & change the solenoid
Don't want to do that, buy the entire starter at auto parts,
not a dealer,cost too much to even be there for any reason.
Sep 28, 2012 | 2005 Nissan Altima
Nissan 1995 Sentra power windows and panel lights are dead. both power windows and panel lights suddenly went dead leaving the windows in up positionor also the radio does not work. I've change
I just answered your other question about this same issue. You need to stop replacing parts long enough to DIAGNOSE the problem so you are not creating further problems by changing all the parts on the car.
May 16, 2012 | 1995 Nissan Sentra
About alternator replacement for 2001 vw beetle gls...I've removed the upper and lower bolts... What am I missing? Alternator still won't budge. Any assistance would be appreciated. Thanks.
all the bolts removed then all thats holding it is the adjustable tube in on the lower fitting ,put a bar in and try moving it then it will move as on the lower fitting with the long bolt is a tube in the alternator housing bracket and this is pulled or pushed out to make contact with the support bracket .Check you havent got three bolts holding it as some vehicles have two bolts on the bottom bracket or one long one
Apr 15, 2012 | 2003 Volkswagen New Beetle Convertible
Replaced slave cylinder, now suddenly it won't start. Has no spark
Can't help you with what you might have knocked or damaged while replacing the slave cylinder.
A slave cylinder is an uncomplicated piece of kit that usually gives good service for many years and few things shorten that life. One of these is using fluid that is incompatible with the seal, another is overtravelling and a third is corrosion.
When the first replacement failed it would be usual to dismantle the failed cylinder to discover the cause of failure, which with only (usually) a single seal to examine would be fairly obvious and might or might not be a reason for a warranty claim.
Sep 11, 2017 | 1988 Jeep Comanche
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
Jun 04, 2011 | LG 47LH50 47 in. HDTV LCD
My monitor suddenly appear a 'dead line' horizontally..
anything can be repaired if you have the money and are willing to spend it. However it would be better to get a quote and weigh up the pros and cons of replacing it cheaper than the repair A new monitor wilol also have 3 years warranty ( Samsung)
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Gateway FPD2275W LCD Monitor
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
Weiser Lock Powerbolt 1000 Lock Logo
1,256 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
