Question about Garden
Snowblower stops running after 15 minutes or so.....why? Starts
Small , fairly new
  • 43 Answers
I know this might sound crazy but try replacing gas cap, or leave it a little lose as test. If the vent in cap is not functioning no air can enter the fuel tank. Then no fuel will come out the hose on the bottom.
Posted on Dec 20, 2008
I have a 2005 land rover freelander in the engine fuse box the f3 fuse keeps blowing 15amp you start the truck go down the road fuse blows it starts runing ruff stop turn off truck then try to start wont...
15 amp is a fair current draw and for it to blow after a few minutes means that there is a short in that circuit that is allowing a drain to earth that just exceeds the 15 amp. It is in the ignition part of the system and may be a bad connection ( water ) or a problem appearing in the ECM or relay . Run fault codes to find the area of the fault. Because it is taking time to blow the fuse, it will be difficult to find. Check all wiring for rub marks .
May 07, 2014 | 2005 Land Rover Freelander
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
My snowblower starts up easy but then it quits
Has it got a shutoff solenoid on the base of the carb? My lawn tractor would run fine for 15 minutes then shut off. Found out it was that solenoid.
Dec 13, 2012 | Garden
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
I can't find my manual for a Tecumsah LawnBoy 824E 8.0HP Electric start snowblower. It starts fine, but does not continue running. I just filled the tank with new gas. It ran to run about 25 feet and then...
Hi
Sounds like a clogged carb which is a common problem for snowblowers due to they set around more then they get used and gas turns stale and clogs carb. Most of the times the problem is in the bolt that holds the carb bowl on it should have 2 or 3 small holes in it. Check that the holes are all open and clean if this does not help you will need to remove and clean whole carb.
Sam
Please vote
Jan 07, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Engine shuts off after about 10 minutes of use
Try loosening the gasoline cap on the engine. My snowblower acted the same way until a mechanic told me it sounds like the engine is not getting enough air. Some gasoline cap vents go bad and starve the engine. If your engine continues to run you can buy a new gas cap.
Mar 12, 2009 | Briggs & Stratton Garden
My 7.75 Hp snowblower starts, runs 15 minutes, then stops.
check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Jan 29, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
I have a snowblower that will only start if I remove sparkplug
GO TO ADVANCE AUTO OR YOUR AUTO STORE AND GET A FUEL ADDITIVE CALLED SEA-FOAM ADD TO GAS AS DIRECTED , YOU WILL POSSIBLY BE AMAZED
Dec 21, 2008 | Karcher 2500 PSI Pressure Washer
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
