Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
It collect water after I use kitchen fosset. I have to push button "cancel/draine for emty it. may be nee to see outlet back valve? Thank you in advance.
    Problem Solver:
  • 5 Answers
Make sure the dishwasher drain hose loops to the bottom of your countertop and secure it there with a strap or a piece of wire. This will prevent water from running backwards from the kitchen sink drain to your dishwasher. This will solve your problem.
Posted on Dec 20, 2008
I have a Maytag super capacity oven and my broiler is staying on even after I push the off button
do you it beep when pressed if so keypad good next test best to have oven pulled out next time this happens while pulled out unplug I know the ignitor will stop glowing what I need to know does the gas valve shut off may take a few seconds if so then relay is stuck on control board
Feb 13, 2015 | Maytag Kitchen Ranges
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Seems to start and then cancels and drains
The flood switch might be turning on. This is the float unit at the base of the dishwasher. Could be the that the spring is faulty. Press and see if it comes back up. Otherwise there is leak in the dishwasher and water has collected at the base under the switch.
May need the actual model number to provide a more precise solution.
Feb 15, 2014 | KitchenAid Dishwashers
I have a Kenmore dishwasher, not sure of the model or year (less than 10 years old) but water constantly flows into the dishwasher. So much so that it leaked all over the floor because the bottom filled up...
Hello.
If it's filling all the time when dishwasher is not even running? The water inlet valve that the house water supply connects to at the dishwasher,is sticking open and needs to be replaced..what you can do now to stop it from constantlu filling is turn off water supply to the d/w from under the kitchen sink.
Typically the model number is on a label on the egde of the door inside or on the rim of the tub..it would be needed to order a water valve
Gene
Aug 24, 2011 | Dishwashers
The machine is not draining fully, even on spin cycle, so that the clothes are still wet when any cycle finishes. Even on the drain option, the machine is not draining all of the water. What is wrong and...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Thank You for using fixya
Aug 11, 2011 | Kitchen Ranges
Had problem with outlets in kitchen, now dishwasher turns on, fills and then shuts off... standing water in bottom.
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
Sep 08, 2010 | Dishwashers
Help - dishwasher won't start when I push the start button. It will, however begin drain cycle when I push the cancel/drain button
Here are couple things that might help, let me know if they do or not.
-The door must be closed within 3 seconds of pushing the start button.
-There is a part in the right front corner of the tub that you should be able to see with the lower rack out, it looks like a hat. This is the float, it will not let water enter the machine if it is stuck up, look to see if something has fallen under it. It should move up and down about 1/4" freely.
- Make sure someone has not turned the water off to the dishwasher, the valve is usually under the kitchen sink
If these do not help let me know if you have any blinking lights when you push a button or try to start it.
Apr 25, 2010 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Water in bottom
This sounds like your backup valve is not closing properly, so the part of drainage water comes back into your dishwasher. You can verify this by disconnecting the drain hose from your kitchen sink drain and pouring water into it. If some of it comes into your dishwasher, the check valve (backup valve) must be replaced.
Dec 16, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
314 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
