Question about Dryers
Ge dryer wont stop running
Cleaned and replaced dryer vent and cleaned inside dryer now dryer wont shut off heats up fine and makes no noises just won't shut off
  • Felipe Estrada III Feb 23, 2009
    Dryer will not shut off.
  •  Sherman
    Sherman May 11, 2010
    does the timer advance
    Genius:
  • 1,122 Answers
HAVE YOU CHECKED THE DOOR SWITCH?MIKE
Posted on Dec 20, 2008
Always on high heat and shuts off after 20 minutes
Check the complete venting system inside the dryer and to the vent outside. Be sure and check for lint & god knows what around the blower wheel. Get everything 100% clean. Insert a thermometer into the vent coming out of the dryer with the vent hose off. Start the dryer on high heat & see if it will go to not over 180% and start going lower like 130% or so if it drops back it's ok . If it don't stop & go down cycle thermostat is most likely bad. The reason it won't start for an hour may be the motor gets too hot. You could put an ohm meter across the connection on the cycle therm and heat it with a small torch or something & see if it will show open after heating. Just a guess lots of things cause these problems. Clean that motor too. Lint may cause it too run hot.
Mar 28, 2014 | Whirlpool Dryers
My GE profile electirc dryer wont shut off when clothes are dry?
venting issue, disconnect vent tube run dryer it will shut off, clean vent tube out.
Mar 05, 2011 | GE Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer will not dry clothes
make sure the vent is clear that runs to the outside of the house.
Jun 26, 2009 | GE DCSR483EA Electric Dryer
GE dryer heating problems
Check the following.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 25, 2009 | Dryers
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
Hotpoint dryer
Completely disassemble your vent from the dryer to where it exits the building. Clean out all lint. Disconnect the dryer from the electrical service and check for lint build up inside the machine. This lint build up usually makes the motor shut down on it thermal overload. Check the motor also to see if the air vents on it are blocked with lint. If no lint is present, the motor or the start relay need to be replaced.
Oct 24, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
