Question about Acer AL1715 17" LCD Monitor
OSD problem on my Acer AL1715 17 in.
OSD menu on my Acer AL1715 suddenly pop up without any reason. Then it disappear after a few sec .. thats very annoying actually. It happens quite often recently, maybe 3 times in one hour .. Anyone has faced to similar problem ? Thanks for advices ..
  • firebird83 Jun 09, 2008
    Hi there
    I'm having the same problem and yes its very annoying, but mine is popping up more often then 3 times per hour more like 3 times every couple of minutes.....hopefully we can find afix for it.
  • Anonymous Aug 04, 2008
    I to have the very same monitor .. plus a secondary phillips 17
    Have you tried clearing windows\prefetch directory of all files ..
    These files are not important ... cached so will be recreated again and again
  • 3 Answers
I had a simalar problem with my Dell 2001FP. The issue is that there is false triggering of the switch; you need to open the front panel, and remove the swictch from the circuit by: 1) analyze the circuitl; its usally pretty simple - a voltage drop circuit. 2) disable the switch by either removing it with a solder gun or, simply by using a sharp blade and cutting the PCB track leading it to it, as I did.(much easier - and reversible!) Fixed my problem.
Posted on Dec 17, 2008
Have found an Analog version of Acer AL1715 OSD version.. It only seems to appears when there is a fault..
How to activate .. When the annoying osd pop's up turn monitor off press and hold the button next to the Auto button; while holding button press the on button.the lcd light should flash amber then green. wait till monitor displays normal then press the menu button.
The Analog osd version should be displayed. What to do after this ?
Don't Know!!!!!!
Posted on Sep 08, 2008
Seems its not acer but a video problem .. try rolling back your video drivers. Mine started happening after a ms update :( guess they though it better to put the faulty driver in bunch of ****
Posted on Aug 18, 2008
Acer what a waste of time this company is. lets all by IBM's / NEC's again atleast they are in for the long hall
Posted on Aug 09, 2008
Nope prefetch folder proved to be jack ...
Posted on Aug 08, 2008
Try clearing windows\prefetch folder..
these files are not important they will be recreated again and again .. with that in mind keep an eye on the folder note new entries
Posted on Aug 04, 2008
  • rexxc Aug 29, 2008
    Acer OSD problem solved .. for me anyway
    two trojan's
    Win32.Trojan.Rbot
    Win32.Polip.A
    Antiviral software never picked them up but ZoneAlarm spyware scanner did .. Deep-inspection scan
  • rexxc Nov 01, 2008
    I've done the driver thing it didn't work. so i had a look at the mouse properties / pointer options
    only cause i noticed that if the mouse sat in a particular spot on my screen the annoying osd popup would appear. so i unclicked all the visibility tick boxes as of this post 3 days later (test) no annoying osd popups have appeared.
    Hope you too have the same good luck.
Same problem and like firebird83 it's a constance popup. Have they had a recall on this piece of ****. I want try any of the other products they make. One screwing is enough for me. If any one can help please help us.....dq379
Posted on Jun 13, 2008
Ma monitor viewsonic 17inches one making lot of trobles by hitting the screen osd lock , how to remove it..?
if the OSD buttons does not work and you see a lock symbol appear, try to press the OSD menu button for about 10 to 15 secs and see if the lock symbol disappears. let me know how it goes and if it works, a rating/comment would be appreciated
Sep 16, 2010 | Computers & Internet
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Nov 02, 2008 | Computers & Internet
SAMSUNG 170 MP LOCEKD-UP
On the front panel press the Menu button for about 5 seconds. Once you press it the OSD will pop up. Keep holding the button until the OSD disappears. The setup should be unlocked now.
Jun 21, 2008 | Samsung SyncMaster 17 in. LCD Television
Osd locked
I had precisely the same problem... I depressed the Menu Button for about twelve seconds or more and the menu actually finally popped up; and does so now every time I depress Menu! Hope this works for you.
Big Jim
Dec 30, 2007 | HP vs15 15"LCD Flat Panel Monitor
Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Jun 14, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Acer AL1715 17" LCD Monitor Logo
763 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
