Question about Apex Digital AVL3076 30 in. HD-Ready LCD Television
TV was on, then it wasn't
Was watching TV when the screen suddenly went near black (audio also disappeared), with only a dim flickering grey light on the left side of the screen. The green "on" light flickered to a nasty reddish white. I tried to turn the device off, but couldn't -- it didn't respond either to remote "off" command or directly on the unit when trying to turn it off. Twice I unplugged, replugged and got same flickering thing. The third time I unplugged/replugged, I get nothing - no flicker, no weird light, and it will not turn on at all.
What the heck happened? Is it dead?
  • kasteuerwald Jan 03, 2009
    I have the same problem. For the past few weeks the television did, on occasion, shut off completely while watching, but we were always able to turn it back on. This last time, however, the green power light flickered orange/yellow and would not shut down completely. I unplugged the set and waited a few minutes. When I plugged the set in again, it would not turn on. Any advice?
    Thank you!
    Top Expert:
  • Apex Digital Master
  • 75,898 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Apr 22, 2017
3 Suggested Answers
SOURCE: Green flashing light on but tv won't turn on
Check capacitors on the power board. Two 1000 uF 25V and one 150uF 400V.
Posted on Aug 15, 2009
techman007
  • 1112 Answers
SOURCE: why is my TV flickering and not taking any
Hi:
Check the power supplu for swollen capacitors, there are ususally two capacitors on the power supply that go bad you can idenify them easily there tops will be puffy on their tops, Also check for the same symptoms on the inverter board, check the two caps on this board also, when the caps become faulty the correct operating voltage to the main board will cause all types of symptoms.
Posted on Jan 24, 2011
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
My LG 55LE5400 TV will not show a picture. The screen is black. I was watching a movie and it just went off.
- Flickering screen
- Dim screen
- Slow start
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | LG 55LE5400 TV
The tv suddenly goes black and the power light blinks red
- Flickering screen
- Dim screen
- Slow start
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
Vizio tv with no power
- Flickering screen
- Dim screen
- Slow start
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=repair%20led%20tv%20screen LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 23, 2015 | Vizio Televison & Video
Phillips TV Model 42PFL7422D/37 that has audio but no video.
- Flickering screen
- Dim screen
- Slow start
Feb 23, 2015 | Televison & Video
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
Jul 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Apex Digital AVL3076 30 in. HD-Ready LCD Television Logo
188 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
