Question about Toshiba Satellite R15-S822 Tablet PC
No sound i cant download realtek ac97 driver when i try it says not verified by microsoft
  • 31 Answers
Go to toshiba's web site HERE for Windows Vista to get the newest drivers. These are tested and recommended by Toshiba for use on this model of computer. Regardless of whether Microsoft has tested them or not, these are the recommended sound drivers.
Posted on Dec 20, 2008
  • 679 Answers
You can download it just disreagurd the message that says that they aren't approved by microsoft. About 20% of the stuff used isn't approved it just means they didn't test it. I have the same driver in 4 machines in my Home, xp and Vista. There is no problem installing a non microsoft approved driver, especially realtek, since most notebooks and desktops come with the hardware you have.
I am try to get the download and driver but it can't find my S/n number
For a driver you don't need a serial number. Most of the time you even don't need to download anything.
The drivers, made for older windows versions, won't work on a Windows 7 or Windows 8. Not even in compatibility mode. Microsoft needed to make Windows more secure, so only allows drivers in there modern operating systems when they have a Microsoft certificate. For a certificate the manufactures must use Microsoft protocols, ask Microsoft for certification, and pay for the tests Microsoft does, to check the software is working correct. So no manufacturer will ask for certification of drivers for hardware they no longer sell.
Long story, but unless you can write your driver yourself, or you can find an universal device driver (not sure something like that exists) you won't be able to use the device.
I saw some dodgy sites trying to offer drivers. Be aware all drivers you can install in windows 7 or 8, you can get them from Microsoft. The ones you could use on an XP computer can't be used, because Windows 7 or 8 won't let you install them. Just for security reasons.
When your device is sold with compatible with Windows x and it is lower version then the one you use, most likely you can't find driver for your device for the modern Windows. Almost no manufacturer will offer drivers for hardware they no longer sell. Success
Apr 25, 2015 | Tablets & eReaders
I cannot access the Internet since February 2013. Had 100% internet connection before that.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html i device arrows key scroll to nstalled.
Apr 02, 2013 | Samsung Galaxy Note 10.1"
Please helpn me dear I have ibmm pc x41..i did formating and new installed of microsoft windows xp service pack 2..after i cant use internet..video driver,ethernet...
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Feb 01, 2011 | IBM ThinkPad X41 Tablet PC
Want to download sound audio driver for M275...which is the one and from where can i download
There are no XP drivers to be found with Microsoft as that OS is no longer supported.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
I hope this helps.
Jan 26, 2011 | Gateway M275 Tablet PC
No sound in my laptop
There are 4 ways you can download and install audio drivers :
1.From Device Manager
(1).Click Start, type Device Manager in the Start Search box, and then press ENTER.
(2).In the Device Manager dialog box, expand Sound, video, and game controllers.
(3). Right-click the device, and click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
(4).Close the Device Manager dialog box, and then determine whether you can hear sound.
2.From the motherboard or installation CD - If your computer came with a motherboard CD, the audio drivers should be on the disk.
3. From manufacturer's website - If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully before installing.
4. Microsoft's Windows Update feature : If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
(1).Click Start, and then click Windows Update (if it is listed).
(2).Click Start, click Settings, and then click Windows Update (if it is listed).
(3).Click Start, click All Programs, and then click Windows Update (if it is listed).
(4).Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Mar 19, 2010 | Toshiba Satellite R15-S822 Tablet PC
My audio card
Did you install the file you downloaded? Run it then reboot.
Jan 10, 2008 | Toshiba Satellite R15-S822 Tablet PC
Toshiba satellite pro l20 sound
my l20 cant play any sound can i download sound through this site
Dec 02, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite R15-S822 Tablet PC Logo
95 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
