Question about Apple Power Mac G5 Desktop
Screen Resolution eMac: 700Mhz: 133Mhz: 768mb pc133 RAM: Installed OSX new, during installation, resolution switched to 640 by 480 and has stayed there since. Zapped PRAM, removed battery, reinstalled OS, etc. Same problem. Splash screen is 1024 by 768. When OS starts, reverts to 640 by 480. In preferences, display shows two windows, each with one of the above mentioned resolutions that can not be modified. I am stumped. Thanks.
  • Loteck Dec 22, 2008
    I love this website. Thanks for the help.
    Sergeant:
  • Apple Expert
  • 250 Answers
Your problem here can be resolved by installing the combo osx update. You can get it from here.
It's 668MB so you'll need to be a bit patient but once you've installed it it will put you back on track.
All the best
Sean
PiDigital
Posted on Dec 20, 2008
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
I need to know what RAM I should use in my Compaq Presario 5000 desktop computer
You have three Ram Memory slots.
EACH ram memory slot's maximum amount is 256MB
Total Maximum Amount for the computer is 768MB.
Uses SDR Sdram ram memory.
[Single Data Rate Sdram. Commonly just referred to as Sdram.
That is a misnomer.
All ram memory from SDR to DDR3 IS Sdram.
Synchronous Dynamic Random Access Memory.
SDR Sdram = Single Data Rate Sdram
DDR Sdram = Double Data Rate Sdram
DDR2 Sdram = Double Data Rate 2 Sdram
DDR3 Sdram = Double Data Rate 3 Sdram
Just thought i would share ]
Uses SDR Sdram that operates at a frequency rate of 133MegaHertz. (133MHz)
Also known as PC133.
Make sure it is,
A) Non-Buffered
B) Non-ECC
C) Low density
D) CAS Latency of 3 (CL3)
E) Uses 3.3 Volts
Here's an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=423457&CatId=828
One more,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146303
For questions post in a Comment.
Regards,
joecoolvette
Dec 08, 2010 | Compaq Presario 5000 PC Desktop
Toshiba sp6000 512mb sdr 133mhz chips
These are the memory modules for your notebook, any others won't work. The max is 1024mb
You need these modules:
PC133 512MB (PA3108U-1M51)
PC133 256MB (PA3086U-1M25)
PC133 128MB (PA3085U-1M12)
If the modules you've installed meet the above criteria then make sure they are seated correctly.
Bear in mind it is always possible one of the modules is defective so try them one at a time, also they are non-eec.
Jul 08, 2010 | Toshiba Satellite Pro 6000 Notebook
DELL Optilex GX110 - RAM
Put the "old" RAM back into the computer, to see if the PC will work at all, or if you damaged the motherboard when you were changing the RAM, or if you accidentally disconnected some cables or jumper-blocks.
Feb 03, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Hardware
Make sure the RAM you bought is on the QVL (Qualified Vendors List) for that motherboard. I know I have had problems with ASUS motherboards and OCZ ram before (for example).
QVL Found HERE
As for the monitor, what do you mean "my Monitor gets disturbed"?
Also make sure you have the games running on the Monitors recommended resolution.
Jun 28, 2008 | ASUS P5VDC-MX Motherboard
Starts without ram but not with ram
The FSB jumper is not for the memory. It's for the CPU.
Set that back to 100mhz and try it again.
Apr 28, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
EMac screen resolution size is only one choice 800x600
1st start it in safe mode.install video driver from motherboard support cd.then start it in normal mode.then you may change your monitor resolution.
Feb 08, 2008 | Apple eMac G4 M9425LL/A Desktop
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
Apple Power Mac G5 Desktop Logo
102 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
