Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printer not responding message when printing from the computer
When printing form the printer standalone it prints fine but whne printing from the computer amessage keeps on popping up "printer not responding"
  • Trpldeuces Dec 29, 2008
    I printed 30-40 pictures from the computer, i changed the black ink and all of a sudden it will not print from the computer. it keeps showing error. The computer was not using the 5300 as the default printer. i delelted what ever else was on there and it still would not print.
  • Anonymous Mar 22, 2014
    when i try to print it is stating printer not responding and error code 15-100003
    Problem Solver:
  • 4 Answers
I had the same problem and it was print spooler on computer.
Check that.
Posted on Dec 20, 2008
Installed new cartridges per instructions but the printer will not print, i get no error lights. i`m at a loss
can you try to make a copy standalone? put a document on scanner and press copy button on the printer.if it is successful,then printer hardware is working fine. you need to insert cd installer that came with the printer in your computer and install it before you can be able to print from the computer.
Jun 05, 2011 | Epson Stylus CX4600 All-In-One InkJet...
The power button on my hp deskjet 3845 is flashing & not responding to pending print jobs. help
it is possible that the printer as a ink issue or thinks it has a paperjam, another thing that can happen is that the print sent to the printer become corrupt locking the printer in a "i dont know what to do" state.
try to run a test print through the printer using the internal test, this is normmaly done by holding down the power button till the power light blinks it should then spit out a print (do this while unplugged form the computer)
**for full test print instructions refer to user manual)
if the driver has become corrupted it also will send damaged print information to the printer
if the test print works fine than you may need to delete all your queued jobs and then run a WINDOWS TEST PRINT form the driver. if this still does not work reinstall the drivers of the printer
(providing the printer will run an internal print)
Feb 08, 2011 | HP Deskjet 3845 InkJet Printer
Not printing - no error message just "not responding"
Are you using xp and do you know how to do a system restore. I would try to set it back to when it worked. Steven 818-888-0006
Mar 05, 2010 | Samsung ML 2010 Laser Printer
Epson workforce 600 continue to get paper jam error and there is no paper jam..
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Dec 13, 2009 | Epson WorkForce 600 All-In-One InkJet...
HP LaserJet 2420 printing problem
Hi all of you
  • try use another data cable.
  • If the printer work proper before do system restore.
Hope this fix your problem,
Thanks
Hamedo
Nov 20, 2008 | HP LaserJet 2420 Printer
All in One Printer/Scanner/Copier will not respond to print command.
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Jul 14, 2008 | Office Equipment & Supplies
Vista with IE7
why dont u check HP deskjet website for printer driver update? may be its avaible there.
May 29, 2008 | HP DeskJet 5650 InkJet Printer
Epson AccuLaser CX11NF
I had this problem. Try unplugging any usb connection to the computer, turn off, then turn on and then try a stand alone copy. It was my USB connection to the computer which had locked up the copier.
After this it was fine.
Jan 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printer won't print in some softwares but will print in others.
Hai
pls reinstall the os and try it will work otherwise there is problem in printer port pls check the setting it will work
Oct 25, 2007 | Computers & Internet
Check ink cartridge error reading won't go away and can't use it.
Switch off the machine. depress all three buttons with the button depressed switch on the machine and hold the button in for a few seconds. Did the problem go away? No? try www.fixyourownprinter.com
Jul 01, 2007 | HP PSC 2175 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
174 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
