Question about JVC TH-M603 System
Disc compartment won't open
When set on dvd, the disc tray won't open and the marker that shows which disc is being played shows 1 and 2. is there a reset button or a way that i can get it to open? Please help!
    Genius:
  • 1,074 Answers
Plug the dvd out then your plug it in back to reset it self.if that do not work take it to a tech to look at it the dvd ould be having a mechanical problem.the gears could be worn out or broken.good luck.
Posted on Apr 01, 2007
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
Jun 12, 2012 | Bush Televison & Video
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Feb 05, 2008 | Televison & Video
I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Oct 17, 2009 | Samsung DVD-1080P9 DVD Player
How to change region codes from only 4 to 2 & 4
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
Enjoy
Apr 18, 2009 | Samsung DVD-1080P8/XEU DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Unlocking zone for samsung dvd-p181
One of these 2 should work.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
<DVD> ; press DVD button
<0><0><0><0><0> ; enter 5 times 0
<repeat> ; press repeat button (careful, not <repeat A-B>)
<5 digit code> ; see below, depends on region the player is currently set to
<0 for region free, 1-6 for other region> ; select new region
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Note: reset player by powering down and simultaneously pressing <power> + <play> until display shows 'reset'.
Aug 04, 2008 | Televison & Video
Brough DVD's from america. Wrong region for Australia. I have a Samsung DVD P181/XSA player. How can I play my dvd's. Is there a way to break the region code on my DVD player?? Thanks Sylvia ...
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 .
OR
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Jul 30, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Dvd player says "no disc"
Could a foreign object have been inserted into the tray? I have seen labels peel off and stick inside the mechanism, preventing it from reading the DVD. Also try unplugging it from the wall, let it sit for a few minutes (for the logic circuits to reset) then plug back in. Just turning it off does not reset the logic...
Nov 04, 2007 | Daewoo DV-6T834 DVD Player/VCR
JVC TH-M603 System Logo
123 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
