Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Hourglass Effect I just got a Hitachi 50'' BigScreen Rear Projection from a friend because the top and bottom would go inward to the middle. I found an STK Convergence Module Pin was loose. Resoider it and works great now. Question is Can I up grade the STK392-110 to STK392-150 without changing the Resistors to higher one? Thanks alot MIKE
  • MIKE Hernandez Dec 20, 2008
    Thanks for the help,
    Just going to wait till it does it again and then swap them out. Till then it works great!
  • averygrl07 Dec 23, 2008
    I am having the same issue. How can I fix it? Where do I find the part you were talking about? Help!!
    Sergeant:
  • 233 Answers
The hitachis USUALLY use 150's, but if it aint broke, dont fix it... IF you did swap it out to 150's from 110's it may or may not work..but, just so you know,you dont have to change the resistors regardless of which IC you use.
Posted on Dec 20, 2008
Warped picture: The top and bottom bow inward giving an hourglass shaped picture. Printing is distorted and the picture is also. At first, this would go away after the set was on a while. Now, the...
If you can solder, resolder power supply board and all of the Big Diodes and you may need to change out your STK ICs STK392-110 upgrade to 180s Better ICs Mats Electronics has them 1-800-628-1118
Mar 17, 2010 | Hitachi 60SBX72B 60" Rear Projection...
The top and bottom are pulling togeather at the top and bottom like a hourglass and the colors are pulling togeather hope this is and easy thing to fix! Has the effect of making it looking double vision
Replace both of your STK ICs big black ICS will have part number on them and theres 2 resistors near ICs 2.7ohms replace them also Call Mats for Parts 1-800-628-1118 Example STK392-020 this might be number of ICs if so use 040s
Dec 09, 2009 | Akai PT4298HD Rear Projection Television
3-d effect it appears on the top and bottom of screen it slowly progressed inward
This convergence out ICs failure symptoms in TV and you need to replace two convergence out ICs in convergence out section / board in TV
if you are not familiar with TV repair then call qualified Tv tech to fix it.
Apr 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 50SBX78B Horizontal lines and bow
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Feb 08, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hourglass shaped picture on rear projection Hitachi 48 inch older
you will need to take the TV and have them diagnosed it for you.
Dec 05, 2008 | Sprint Hitachi P300 Cellular Phone
Hourglass effect and fuzzy
You have a convergence problem and I suggest to get a qualified honest tv repairman because this is a highly technical problem in this model. Hope this helps
Dec 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
