Have weatherking furnace, Pilot lites but no blower
Comments:
Dec 20, 2008
- yes it does, The blower is not kickin in
Thank you
Dec 20, 2008
- Thanks skeeter, I have a weatherking upflow furnace. I do have a meter. I hope the IFC is not the problem. I hear the burner running for a few minutes. Then it stops. I placed the thermostat from auto to run with nothing happening from blower.
Dec 21, 2008
- Hey Skeeter.We had a snow storm the other day. The old guy next door covered my air ducting. went outside shoveled it out and presto, Furnace worked. Thanks for all your help though.
I am thinking the fan is bad if you can disconnect the fan motor leads and ohm them out. White is common Red is low speed Black is high speed. You might have other colors like blue which would be med speed and maybe orange witch would be med low. There is a small run capacitor on the fan so replace both fan and capacitor at same time. After you ohm out the motor of course. You should have resistance on all leads. Use white as the main one and check each speed. Replacing the motor isn't too tuff little hard getting it out of squirrel cage
Comments:
Dec 21, 2008
- Good deal but man your neighbor you better talk to him and let him know what he did. thanks
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
i have an air conditioner Samsung AQV12VBA. It does not operate on the heat mode. Error code...
(More)
i have an air conditioner Samsung AQV12VBA. It does not operate on the heat mode. Error code diaplayed is E5 54.
i have a PAC CT90 portable AC with a drain hole
located at the bottom back -- but i can't get...
(More)
located at the bottom back -- but i can't get it
to drain
