Question about Sony VAIO VGN-FS640W Notebook
I Have sony vaio vgn fs640w. I am unable to increase of decrease sound using function key and same with brightness. I have tried your solution by uninstalling the motherboard driver but still its not working... What should i do...??? any suggestions..?
Sony voia vgn-aw15g/h keyboard eject button won't function after windows 7 upgrade from Vista
http://www.sony.com.au/support/product/VGN-AW15G near the bottom of page you will find your missing drivers and the instructions for installing them
Feb 26, 2013 | Computers & Internet
Keyboard brightness control
Look on the keyboard for the keys that might have a circular looking sun (circle with sprockets) on it. Usually they are next to each other with up and down arrows to represent increase or decrease brightness.
You will probably have to Press and Hold the FN function key located at the lower left portion of the keyboard while you hit the key that controls the brightness.
Jun 05, 2012 | Sony VAIO VGN-FS850/W PC Notebook
On VGN-FS640W screen is very dim, as if it were on battery. Is there some setting I can change to make brighter?
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Apr 04, 2011 | Sony VAIO VGN-FS640W Notebook
Where and how do i adjust my brightness
Normally this is easily specified on the keyboard, look carefully and there will be a blue or a red lettering. The FN keys along with the indicated cursors will decrease or increase the brightness.
Dec 11, 2010 | Sony VAIO VGN-N365E/B Notebook
How to adjust the brightness on my sony vaio pcg-k17?
To adjust the brightness control, press Fn + F5 and release, plus the RIGHT ARROW or LEFT ARROW keys to increase or decrease the value.
On most notebook computers you can use the Fn+F5 keys to lower the screen brightness level, and the Fn+F6 keys to raise the screen brightness level.
May 18, 2010 | Sony VAIO K45 Notebook
VAIO VGN-Z520N/B 13.1" Laptop : where is the volume control on sony vaio laptop...
You can use the Fn+F3/F4 Function Keys to control the volume.
To increase the Volume, press Fn+F4 and then press Up or Right, or Keep pressig Fn+F4.
To decrease the volume, press Fn+F3 and then press Down or left, or Keep pressing Fn+F3.
Hope this helps..
May 13, 2010 | Sony VAIO VGN-Z520N/B Laptop
Sony Vaio vgn-fs640w does not power up nor does it
I went to the Sony Vaio support site for your model specifically and they mention a battery recall. There is a place on the site requiring specific information about your system and your battery to see if you are eligible for the recall. I would try this route to see if it resolves your issue. If not, I would say it is a blown transistor and you need to replace the motherboard. This means buying a new system, as Sony VAIO laptops are very proprietary and hard to find parts for.
Good Luck,
NOLA Tech
Feb 06, 2010 | Sony VAIO VGN-FS640W Notebook
Sony vaio vgn-nr160e with vista, function+ keys wont work
To enable the Fn keys functionality, you need to install the "Vaio Event Service" and "Sony Utility Series"
They are available to download as part of a package from the Sony website. Here is the link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR160E&upd_id=3262&os_id=28
Regards,
Purito
Oct 18, 2009 | Sony VAIO VGN-NR160ET Notebook
VGN-FS640W - Three green LED's come on but no boot up.
your hardrive is going bad cannot read the disk.take hardrive out and tap it slightly? then replace see if it makes a difference..
Jun 17, 2009 | Sony VAIO VGN-FS640W Notebook
@nd function on keus
It appears that the function key is stuck on. try an external keyboard. if the external keyboard has the same problem its an issue with windows but if not you could be looking at a replacement keyboard. hope this helps Peter
Mar 28, 2007 | Sony VAIO VGN-FS640W Notebook
Sony VAIO VGN-FS640W Notebook Logo
102 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
