Back to:
Tags:
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Lack of Suction (by 2 users)
posted by DMcC on Apr 01, 2007
I just bought The Oxygen 3 and everything was working fine up until today. Suddenly there is no suction when the big carpet head is attached to the vacuum. The suction is working fine without the attachment, but that doesn't help me vacuum the floors...HELP!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by red98head, posted on Sep 12, 2008
I have an older version of the Electrolux canister vacuum. I must say, it's by far the best vacuum I have ever had and it's a hand me down from my grandparents. I have owned new vacuums and they do not compare to the power of this vaccuum.
My problem is the same, that when the floor attachment is on, it doesn't ****. I changed the belt and the brush still isn't spinning. I also do not hear the motor running. I looked for any frayed or disconnected wires but I see nothing. Is there anything else that it could be?
Best Solution
posted on Apr 03, 2007
Helpful (85)
tresilla
Rank:Guru Guru
Rating: 86%, 1197 votes
only possibility is a blockage in the carpet head
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lack of Suction:
I don't want to Accept this solution
Solution #2
posted on Sep 10, 2008
Not Rated (0)
Rob Ristin
Rank:Guru Guru
Rating: 90%, 36 votes
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Thank You!
Can you Help with these Vacuums problems?
Vacuums
bosch ergomaxx model bsg82000gb/01 bagged vacuum cleaner...
Electrolux EL7020A Oxygen 3 Ultra Canister...
Just a very weak rewind action on the power cord. Is it...
the power wand seems to have a short, the light flickers...
Hi! I've been having a problem, when I hit the button to...
Hello,  I own an Oxygen 3 Ultra that has had some...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
