Question about Dell Axim X5 Pocket PC
Can I use Standard 4G or 8G SD or Cf cards in a Dell Axim X5?
The Dell Axim X5 PDA was built when SD and CD cards had a capacity of 2G. There are now Standard SD and CD cards of 4G, 8G and larger. Will my Dell Axim X5 work with any of these higher capacity cards?
  • 4 Answers
SD cards must be SD not SDHC, there is not an SDHC driver for the X5. You can find regular SD cards up to 4G.
CF is no problem, all flash based CF cards will work. Microdrives can be problematic.
Posted on Feb 24, 2009
I can use a standard 2GB but I would advise just trying it. Flash memory is so cheap now it might cost you like $10 to get a 4GB and try it out. If it works, great, if not, you are out about $10 unless you have another device you can use it in.
Posted on Jan 14, 2009
My DELL AXIM X5 CF SLOT not fuctioning
Check the pins inside the slot. I had one that bent and the cards were no longer recognized
Sep 14, 2008 | Dell Axim X5 Pocket PC
Good Eevening :
You could get original disk from ebay at times but all you need is the Activesync that can be downloaded from Microsoft. Get Active sync 4.2. The newer ones do NOT work with the X5.
Good luck with the wireless card. The Axim does not play well with many of them. (sometimes works but mostly not) Try drivers from d Link and be sure to remove the old drivers first.
Dec 02, 2007 | Dell Axim X5 Pocket PC
Wireless compact flash card installation on dell axim 5
Go to Wal Mart and buy a 1 gig SD card----- and then buy a AmbiCom 54G wireless CF card. Works perfectly in my X5.
Oct 30, 2007 | Dell Axim X5 Pocket PC
Speed of CF vs SD in Axim
The reason CF COULD be faster is that it is a parallel connection (16bit IIRC) while SD/MMC is serial in nature. Now, assuming the INTERFACE were the limiting factor in the speed this could become significant. Unfortunately the interface is NOT the limit (in most cases), the limit is the actual fetching of data from the memory itself. Being Flash it is nowhere near as fast as some of the other types of memory we are used to. It is especially slow when being written to. Newer cards out there are faster then older ones, but in the end I doubt you would notice much if any difference between the speed of a CF versus an SD/MMC card
Sep 14, 2005 | Dell Axim X5 Pocket PC
Confused about the WiFi on X5
It does NOT have integrated WiFi, you will have to buy a compact-flash card, the Linksys WCF12 works perfectly in mine.
Help : Can I access Memorysticks on AXIM
Since a SD memory card is about the same size [width and thickness] as a Memory Stick, I doubt there will ever be an adapter available between these two formats. There just isn't any room unless they came up with a very large adapter which would stick out and be unwieldly. You can get Compact Flash adapters (which are much larger) from a company called Pretec for about US$59.00, plus I'm sure there are others. I use a full sized PC Card adapter on my laptop to convert between the SD Memory card for my Axim X5 and the SmartMedia card for my digital camera and MP3 player.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can I use 256M in Axim
Not sure about the SD but I don't see why not, as for CF I'm positive it'll support ANY size cf card out there...
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Dell Axim X5 Pocket PC Logo
601 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
