I have an LG DVD Player (Model DS9481 CPE) - I have a DVD that is recorded in PAL2 Format. Is this format recognized by this DVD Player? Is is possible to change the DVD Player settings which would allow recognition of both NTSC and PAL formats? Please advise.
  • a_chhibber Dec 20, 2008
    Thanks, the DVD is not recognized and it throws a DISC ERROR message. However, I believe that this particular model does support PAL Format, in addition to NTSC. So, coming back to my earlier question - "Is there anyway to change the DVD Player setting to read/recognize PAL format?"
    Thank you for your response.
    Regards.
Welll you can try whether its working or not or else you can convert the format of your dvd by various converters into the compateble one.
Posted on Dec 20, 2008
Phillips dvd player recognizes usb flash drive but wont open it
might need to format the flash drive to the phillips dvd player. make sure you back up whats on the flash drive first. plug into dvd and format it. the player should ask you if you want to format flash drive. because when you format the flash drive it will erase all data on it. then reload the data back on the flash drive. try again
Apr 17, 2014 | LG DN898 DVD Player
Can't read DVD+R that were recorded on LG-DR389 on my PC / Laptop DVD
The DVD+R is the older version that was used, all newer ones use the DVD-R now, your problem is the disc is not recognized in the other players because of the different format.
Mar 18, 2012 | LG Televison & Video
My cd/dvd player do not open cd or dvd automatically and I must go to my computer to open up the cd or dvd. Sometimes it ask if I want to format the cd even if it is an original
Your DVD player does not recognize the format that is put into the disc and so does not read.
When it is put into the PC , it might ask for formatting but is not possible when it is a only read disc.
So check the format you have recorded to be acceptable to the player .
Feb 23, 2011 | Computers & Internet
How do I transfer recordings off my lg hdd RH1999H to my laptop? Is it even possible?
The generic answer is yes you can. You will need to use a software app like Pinnacle Studio V10.5 onwards (currently V14) or similar II think that Roxio have a product too) that will take raw video format from the DVD Player / recorder and convert it to MPEG2 files that you can then convert to any other format. You can then edit them and put them back tot he DVD Player / Recorder in the correct format for viewing on TV. This will also allow you to burn customised discs with TV content etc.
Oct 18, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Doesn't read my DVD's burnt off my mac anymore
r u sure the format for your DVD that u burnt from MAC is same as DVD that usually can play in DVD player?try to compare your burnt ne with ordinary DVD that can play ib your DVD player...if it is not same, then u have to burn it by using the same format as your ordinary DVD..or if it is same, then your DVD player cannot support the type of DVD that u use...for example like DVD-9, most cheapest DVD player cannot recognize the type of DVD that is used eventhough u use original DVD...
May 26, 2009 | LG DR197 DVD Player/HDD Recorder
I have stand- lone Toshiba DVD Recorder/player model No RD-Xs32SU which has a Maxtor Diamond Max 16 80GB HDD. This drive is kaput. I am looking for a replacement, and information on whether the DVD Rec...
The answer is to replace the hard drive with exact same specs (80GB, ata 133,5400rpm) formatted Fat32 and completely empty. Machine will format/recognize it and will be operable.
May 27, 2008 | Televison & Video
Recorded DVD won't play on computer or other players
Yes it might be the format of the recorded dvd, check in which format it is and you can then download the codecs for your PC movie player via google. If you can give me the format I can try and find you a link to the codecs you need if you like.
Goodluck^^
Mar 24, 2008 | LG DR198H DVD Recorder
DVD er Help
Broadcasting
Video : PAL I, B/G, I/ISECAM D/K, K1
That information is posted on LG Australia's
website that you hyperlinked to. It won't play
NTSC video because the region coding is
different - on PAL video is supported.
Sorry to be the bearer of bad news :P
Hope this helps,
Justin
Feb 19, 2008 | Televison & Video
Samsung dvd recorder model vr-325
Ok I have been here before. The problem is your DVD burner in your DVD player unit may not be burning the disk in a format recognized by the Computer, or the laser may not have burned the disk to the set standard, and while it can play on that DVD player when you move it to a nother player it will not play. Well what we can do is Test the reverse first. Burn a DVD on your computer and try to play it on your DVD player and on the other TV. Then what I want you to do is to clean the lens of the player and try to burn a disk and play it on your computer. Let me know how this truns out.
Sep 10, 2007 | Samsung VR-325 DVD Recorder / VCR Combo
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
