Question about Nikon Speedlight SB-600 TTL Flash
SB-600 will not turn on
My flash does not turn on and I have tried to reset and unlock. I'm not if I am doing it correctly, so any help would be great.
  • wehii Dec 26, 2008
    I've tried new batteries, cleaning contacts, using dielectric grease..I can't get my unit to power up. It's been six months since I have used it.
  • bozzcm Jan 26, 2009
    i tried new batteries,then recharged my ni cad bateries to full,still dead as a doorknob,any ideas,its aways been in a case,never abused or got wet either,stymied here,help!
I had the same issue, the unit would not turn on.
The issue was coming from the battery compartment. the battery were a bit lose and I had to bend out the contact at the bottom of the unit to make it work again.
The 2 battery with the + facing up were the problem.
I have inserted a small screwdriver to bend the contact upward a bit and the unit is now working fine.
The batteries don't make noise anymore when I shake the unit, it was make a bit of noise before.
Hope this help to fix your issue.
Fred
Posted on Jan 29, 2009
Attempted to clean the contacts with contact cleaner and it didn't work - used vinegar and this sems to have worked
Posted on Feb 01, 2009
Use Fine Grit Sand Paper and rub all the shiny contact points including the battery. Works magic!
Posted on Jan 27, 2009
    Novelist:
  • 170 Answers
Remove the batteries. This will reset everything. Re-insert, Turn the unit on, wait for the ready light, then select your flash setting option. Test flash it a few times. Be sure the flash head and diffuser is capable of sliding with the zoom lens focal length and not blocked by anything like tape or a diffuser.
Posted on Dec 20, 2008
I have a sb-600 flash. It works fine but it has
Try doing a reset - press the "Mode" and "On/off" buttons together for a few seconds and you go back to factory settings. Sounds like you got into some funky mode, assuming everything else is working ok.
Mar 09, 2010 | Nikon Speedlight SB-600 TTL Flash
SB-600 display shows, but will not fire or test fire
there's a part in inside that triggers the light .. it might need to be fixed.
Please contact Nikon Tech Support to walk you through resetting the flash.
a. Have you tried that? it's in the Manual
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 keeps firing
I believe that there is a safety feature built in that if the voltage in the capacitor gets too large the flash will fire, to prevent damage, could be this that is faulty, if it is a new main circuit board is required.
Aug 31, 2009 | Nikon Speedlight SB-600 TTL Flash
SB 600 wont turn on
Did you overheat it?
I know this is basic, but are you sure the batteries are good and installed correctly?
Jul 07, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Flash is not working for a nikon sb-600 speedlight
    zoom the flash all the way in so you can see if the flash bulb is broke
    Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
    SB-600 will never be on ready
    The capacitor may be weak, or there is a problem at the component level that is not allowing the inverter to reach full voltage.
    The flash will need shop service.
    Jerry G.
    Apr 20, 2008 | Nikon Speedlight SB-600 TTL Flash
    Sb-600 not beeping, images completely black (underexposed)
    Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
    I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
    Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
    SB 600 Not resetting...
    my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    549 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
