Question about RCA WSP150 Main / Stereo Speaker
Wsp150 transmitter failure
After owning this system for about a year, the transmitter will only take power for about ten seconds, and then the green LED blinks off. Disconnect power inputto transmitter, then replug,powers up, good for another ten or less seconds, on and on. No noticable audio signal even during those ten seconds. Have read of others with same problem, but no solution seen. Opened case, smelled for transistor burn out, none detected, reassembled, no change in symptoms.
  • 10 more comments
  • JMike Nov 21, 2007
    I have a WSP150 Wireless system from RCA. The transmitter, when plugged into the power supply (19V) will flicker green for a second, but will not come on.
  • Anonymous Dec 21, 2007
    I found a problem where the dc power jack meets the pc board on the transmitter. I saw actual arcing at the solder joint. I heated up the joint
    to remelt the solder, but then it didnt work at all after that.
    I had the same thing, it would power up, die. Pull plug, power up, die.
    I thought it was the power plug, that proved good so I went into the transmitter and checked the jack itself thus discovering the arcing.
    Wonder if anyone else has seen this problem.
  • wsp150 Mar 02, 2008
    I have the same prob with transmitter. If you have any info on getting  mfr. to repair I haven't had luck finding a fix
  • Anonymous Apr 11, 2008
    We are experiencing the same problem as the the Tinker! The transmitter will only stay on for a few seconds then the green light turns off! We did disconnect the power input to the transmitter, then reconnect then stays on for a few more seconds and off again! Was not aware of this problem till searching the internet. We also opened the case, tried it with another set of speakers & still the same problem.Nothing appeared burned, put it back together & still no change. Sure could use a new transmitter!! The speakers are useless without it! These were a gift to us & have had them approximately 7 or 8 months. How about a little help with this?? Thanks! Bert
  • Gmanne May 12, 2008
    same exact problem
  • colorado guy May 19, 2008
    the transmitter will only take power for about ten seconds, and then the green LED blinks off. Disconnect power inputto transmitter, then replug,powers up, good for another ten or less seconds, on and on. Now the power transformer died. Where do i get a replacement with a 19 volt output?
  • slobeachgirl Jun 13, 2008
    We are having same problem. Husband has tried hard solder from power to board but still not better
  • Anonymous Jul 04, 2008
    Mine does not even come on. Speaker's green lite flickers ...no sound.
  • figster Sep 10, 2008
    I have the same problem - green indicator light goes off after 5 seconds - unplug and plug and it does the same thing. Do I need a new transmitter and if so can I use another name brand -something generic.
  • myro1 Nov 02, 2008
    Same game here. This stinks!
  • Anonymous Dec 01, 2008
    I have the exact same problem...does anyont have a solution? The holidays are fast approahing, I need my wireless speakers!
  • Micky Feb 02, 2012
    I fixed mine today by opening and removing the board, gently heating, removing the ground and the 3 post power input along with any solder. Gently remove surface layer exposing metal board connection. Flux and resolder carefully as there are other solders very close to each other. The problem is not the post to the solder on back, its the post and solder to the thin metal board. It now works like new again. Good Luck! ps. dont use a torch unless its micro youll burn it up.
The following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume. If the volume is too low, the transmitter will not turn on.
Posted on Apr 12, 2009
  • Susan Nov 23, 2011
    What a simple but effective solution......worked for me! I thought my transmitter had died.
Everyone, turn up your volume on the computor all the way up.This gives the transmitter a better signal.you can control the volume at the speaker..Good Luck
Posted on Jun 22, 2008
I need RCA WSP150 speakers! If your transmitter is fried that is okay I only need the speakers.
Bill
Posted on Sep 16, 2009
    Genius:
  • 1,074 Answers
Your system has a power problem in the power supply make chacks on the regulator it might have a open,if you are not a tech let a tech take a look on your set to verify the damage componet good luck.
Posted on Apr 02, 2007
I have the speakers and power adapter but i can not find the transmitter....can i purchase the transmitter only..??
any transmitter will work by RCA..... The one for the WHP141 works just fine and that headphone set w/transmiter is about 19$ on Ebay as well as other places, be aware that the transmitter will not transmit UNTIL the sound source is hooked up and the sound is high enough to trigger the transmitter into working..... do not expect the green light to come on simply because it is plugged in, because it wont.....also if the sound is not high enough from the source the sound will cut in and out......notice also that the transmitter power supply is the 19 Volt one, and the tip is - and the out side ring is the + reversed of what many after market power supplys are.........the cool thing is the gain of a set of decent head phones as well as being able to use the speakers.....so many people fail to even READ the instructions and think that the units are defective because the green light does not stay on when pluged in......pays to read.....
Dec 19, 2011 | RCA WSP150 Main / Stereo Speaker
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
Where can I get a replacement RCA WSP 150 transmitter? I think mine is bad.
The transmitter does not turn on unitl there is enough incoming volume from the sound source.......it does NOT turn on the green light simply because it is plugged in........the volume is critical.....
Mar 05, 2011 | RCA WSP150 Main / Stereo Speaker
When I plug in the power supply to the transmitter the green light goes on only for a split second and goes out. If I wiggle it back and forth and it and out I can't get it to ever find a spot where it...
the sound source MUST be hooked up and running INCOMING SOUND to trgger the transmitter to work.the green light DOES NOT STAY on simply powering up the transmitter......
Jan 15, 2011 | RCA WSP150 Main / Stereo Speaker
No power light on transmitter. Measured correct voltage at power-in.
the light does NOT stay on .....because it was not designed to.....takes INCOMING SOUNDwith the transmitter plugged into the sound source to make the light stay on......
Oct 02, 2010 | RCA WSP150 Main / Stereo Speaker
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Wsp150
Turn up your computor volume all the way up and adjust the volume at the speaker,..Ted
Dec 13, 2007 | RCA WSP150 Main / Stereo Speaker
RCA WSP150 Main / Stereo Speaker Logo
1,630 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
