Question about Air Tools & Compressors
Air compressor starts slowly and then trips 20 amp breaker.
The compressor turns freely by hand. Could this be caused by the start or run capacitor?
  • fishingdaddy Dec 21, 2008
    It is a 4HP 110 Volt Craftman on it's own circuit with a new 20 amp breaker.
Jsd
Posted on Mar 07, 2010
  • db990 Mar 07, 2010
    there is a valve which releases air pressure from the 'compressor' part of your unit when the motor stops. this avoids ther unit re-starting under load. if this is not operating properly the unit will struggle to get going and therefore the motor will draw too much current for too long causing the trip-out.
  • db990 Feb 11, 2011
    this won't help the original poster but, for anyone else reading, i have also found a bad capacitor or centrifugal switch on a single phase motor can cause this.
    the capacitor is a biggish can shaped object with a lead that connects to the motor windings either directly or through a centrifugal switch (if present). cost about 10 or 20 quid for a new one.
    the centrifugal switch is a switch (obviously) that will be found within the end casing of the motor. it disconnects the capacitor as the motor speed reaches a cetain level but maybe stuck open. may need cleaning/freeing up.
  • 67 Answers
Sounds like the oil is cold. Let all the air out and let it run for 3-4 minutes without building any pressure to warm the oil.
Posted on Jan 01, 2009
    Scholar:
  • 65 Answers
Is it 220 or 110 ? How many horse power is it but most importantly is how many amps is the motor itself? If it is 15 amps let's say then that doesn't leave much more for anything else to be running on the same circuit of which you have the compressor plugged into. While 110 is more convenient, I know that is my preferred choice, when you get to 3 HP or over size motors your looking at close to or right at 15 amps of supply needed. Could also be the breaker needs replacing. Hope this helps.
Posted on Dec 20, 2008
Window a/c compressor runs. fan hums but does not run
Replace the fan. The bearing is worn and it may need a new capacitor.
Jul 14, 2012 | Whirlpool ACQ158XP Wall/Window Air...
Campbell Hausfeld VS5006 Compressor runs slowly
Rmove the drive belt and check the motor. It should turn very freely by hand and if turned on should start up easily. If it turns hard check the armature bearings if it starts slowly but turns OK after you give it a push, you have a bad start capacitor. If the motor is OK check the pump. It should turn fairly freely except on the compression stroke where you should feel slightly more pressure is needed to turn it. If you can't turn the flywheel or it turns very hard, you should check the connecting rod to crank shaft joint and crank shaft bearings. These usually go bad if there is low or no oil in the crank case.
Apr 08, 2012 | Air Tools & Compressors
My dental compressor stopped working. What can I do?
Does it make any noise at all? If not, check the motor for a protective device. A thermal reset would be a red button on the end of the motor. It may be as simple as that.
If it hums loudly, and turns over by hand- no power applied- with difficulty the motor bearings or compressor bearings may be needing attention.
If it hums loudly and barely turns, but turns by hand freely, the motor has a start/run capacitor- it likely failed. Replacing the capacitor is a simple task- just make sure to replace it with one of similar ratings.
Feb 14, 2012 | Air Tools & Compressors
The ac is not fully turning on. It sounds like the compressor starts to run, but the fan does not and eventually turn off. With the unit off, i turn the fan on and it sounds like its trying to run but its...
The first thing you should do is make sure the fan turns freely by hand. If it does then check the capacitor and replace it if it's bad. If the fan doesn't turn freely then you may need a new fan.
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
Fan wasn't comng on but compressor did. I spun the fan by hand and it started. Now the compressor keeps turning off
Is the fan still running after you started it by hand? If it's not it will cause the discharge pressure to go up on the compressor. The capacitor may be bad and causing the fan not to come on.
Aug 13, 2010 | Frigidaire Heating & Cooling
Fan not moving
first,with power off,try to manually turn the fan by hand,it should turn freely and coast to a stop by itself,then if so,there is what they call a "dual-Capacitor" inside the unit and one side of this capacitor is the motor start/run capacitor and they go bad,it is a silver can with 3 terminals marked F/C/H fan/common/hermetics (for the compressor), and will say something like 5uf./35uf at 440 volts A.C. on the body of this component go get a replacement at most electrical outlets
Jul 28, 2010 | Weather King 10AJA6001AH Air Conditioner
Compressor will not run
could be the capacitor, also try looking at the wires around the windings
May 17, 2010 | Clarke Power Products Inc AC2001 2HP 4...
The compressor on my air conditioner was still running, but the fan was not running causing the temperature to climb in the house. I re-started the main power and the fan worked with the compressor wants...
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 20, 2009 | Heating & Cooling
Air compressor flips breaker before it will start?
Air compressors tend to draw more power as they age, however, will not trip breaker unless some malfunction. Here are some simple tests. Unplug compressor and turn the pump by hand, you may have to remove a cover to do this. It should turn freely; any resistance could be failing bearing (would make noise) unloader/check valve leaking allowing back pressure to pump, or failed start capacitor/start winding. Easy test for checkvalve. With pressure in tank loosen discharge hose at tank and check for air leak. Check valve should hold pressure in tank. Replace as needed. Failed capacitor/s will cause high amp draw. Remove from circuit and test. UF reading should be within 95% of printed rating. Finally, most air compressor motors have two windings, start and run. Power to windings is controlled by flyball switch inside rear of motor. This switch has contacts that can stick in start position and cause high amp draw. Examine windings for signs of overheating. Copper windings generally have color of new penny. Very dark brown windings bad news. Gook luck
Jan 06, 2009 | Air Tools & Compressors
Compressor will not start
It is a good sign that the motor turns freely with and without air. That indicates that you have good bearings and that the intank check valve is in good condition. Next you should check the capacitors and the condition of the windings. Some motors have start and run capacitors and others only have run cap. Remove from the circuit and test with meter having cap. test setting. Most shops will test them for free. The cap should test within 95% of stated ( uf ) value. Replace as needed. Finally check that the flyball switch at rear inside of motor is functioning correctly. At rest, switch is at start winding, then a split second after start, it shifts to run winding. Check contacts are not stuck and that switch is working and lastly that the winding are the color of new penny. Good luck.
Jan 06, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
1,111 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
