Question about KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range
DOOR ON KDRP467 WO'NT OPEN
THE OVEN DOOR WILL NOT OPEN
Replace the control panel thermal
fuse (Microtemp G4A01093C). Its in the wiring harness between
the control transformer and the control panel on a blue wire.
It looks like a resistor inside a clear plastic tube and is
mounted on a metal bracket with plastic clips. It has a spade
connection on each end. It can be accessed by removing
metal access panels from the back of the range and it
is in the area below the gas burner deck.
Posted on Dec 29, 2008
I took my microwave apart to fix the broke spring in the door & put everything back exactly the way it was &it wo nt do anything ??????
Bad luck. Are you sure you mounted everything everythinh exactly the way it was? No pieces missing or left over?
Best procedure is to that a photo of each step.
My adivec: Do it agaim carefulley. I no luck, look for a repair service
Maybe you can fine a video tutorial for your Microvwve in youtube?
Something like this
Broken microwave door
Samsung Microwave Door Latch Spring Repair when your door won latch closed
Over The Range Microwave Oven Door Repair Help
Repair Replace bad Door Switch Mechanisms on Whirlpool Microwave
and there are come more
Oct 28, 2015 | In Microwave Ovens
After installing int explorer9 iolo system mechanic stopped working.Trying to open System... it simply wo'nt open
It might be a software incompatibility issue.
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Oct 01, 2011 | Iolo Technologies System Mechanic: Windows
While cleaning oven the door hs remmained locked even after oven has cooled down
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Oct 13, 2010 | DCS WO-130 Stainless Steel Electric Single...
Wo nt come onmy son pressed the ac power button while i was installing a sky hd box and now it wo nt come on
Hi i haven't had this problem before but i can try to help but i cant guarantee it will work.
First of all i would try turning it off and unplugging it by the switch for 30 minutes making sure you remove the card.
Then i would turn it back on and try from there.
If it still doesnt work i would try changing the fuse and if still no luck you have no choice but to ring sky because your box might have blew something inside it.
Hope this helps :)
Carl Redding
Jul 05, 2010 | Televison & Video
GE Profile range oven door
foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
Mar 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Feb 09, 2008 | DCS WO-130 Stainless Steel Electric Single...
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range Logo
221 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
