Question about Panasonic 5.8 Ghz Cordless Phone System
Panasonic phone won't call out, just stays on dial tone.
A cord phone works fine on same line. None of the 3 handsets will call out.
  • 22 Answers
SOURCE: problems with handsets
Are they cordless phones?If they are they get there dial tone from the base.If there is a blinking red light on the hand sets they lost communication with the base.Check your user manual to see if you need to program them to the base.
tk46
Posted on Jul 20, 2008
  • 31 Answers
SOURCE: No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Posted on Apr 16, 2009
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
Phonesmith
  • 113 Answers
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Posted on Mar 19, 2010
Testimonial: "Thanks Heaps Buddy"
pishta68
  • 579 Answers
SOURCE: my panasonic phones do not ring when an incoming
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
Posted on Oct 19, 2010
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
I was storing some extension numbers and spead dial numbers and I must have done something wrong as anytime I pick up handset to make a call a 'reorder tone' message comes up on the display- this is before...
So don't pick up the handset :-)
There are some line preference and pickup dial programs that just happen to sit in PROGRAM 1x. My guess is that you have assigned an empty or invalid pickup dial code to the phone.
Try this first. Press PROGRAM and dial 12 ENTER. Is the Hot Line mode ON? If it is, press SEL and ENTER. Wow. That was easy :-)
Didn't work? Let's go for Preferred Line Outgoing next. Dial PROGRAM 19 and 3 ENTER. That makes the intercom prime (0 is none, 1 is idle line 2 (xx) is a specific line).
If you tried both of these, and still no joy, then it's time to reset the phone. The problem with that is you have to dial the code IMMEDIATELY as you're picking up the handset. Good luck with that. The reset code is 79# or 790.
Carl
Jan 25, 2011 | Panasonic KX-T7630 Corded Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Panasonic KX-T7433
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Problems with handsets
tk46
Jun 09, 2008 | Panasonic KX-TG1033S Cordless Phone
FAX function stopped working
honestly, it sounds like you have the phone cord and the fax jack swapped backwards, make sure you have the fax line plugged into the correct jack on the machine. 1 is for the handheld phone and the other is for the telephone line... give this a shot...
Mar 10, 2008 | Brother MFC-7220 All-In-One Laser Printer
Panasonic 5.8 Ghz Cordless Phone System Logo
735 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
