Question about Sony STR-D1015
My sony str-d1o15 says protector
When you power it on, it powers on for about 3 to 4 seconds and then says protector. i dont know what to test ,how to test it or where it is. can someone tell me cause i dont have the cash to have it repaird or replaced? i heard a ic stk 350-230 might be to blame. is that trur and how do i find , test it?
  • Anonymous Dec 27, 2008
    I have the same problem. Was working fine then low and behold "Protector Mode". Any solutions?
  • nwcf Feb 04, 2009
    This is strange as I just had this happen too. Turned it on and flashing protected. I cannot find my original manual so was searching online for a clue. Maybe has a self destruct date code built in so they can sell more products.
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Posted on Feb 04, 2009
Fan protector message on reciever
check power supply and drive circuits
May 21, 2012 | Sony STR-DA30ES Receiver
Message "PROTECTOR"
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts. If it cuts out, it needs service. If you need detailed troubleshooting help on this after testing receiver without speakers connected and it passes, post a comment and I can walk you thru it. Hope this helps.
Oct 24, 2009 | Sony STR-DE625
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 03, 2009 | Sony STR-D700SS Shelf System
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
I got this from Sony site, I am doing it to mine now, unplugged it first.
Dec 20, 2008 | Sony STR-D1015
Protector mode..
Cambiale los IC de audio que esten dañados.
Oct 13, 2007 | Sony STR-DE825 Receiver
514 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
