Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
No power? do the kenmore direct drive heavy duty series 80 washing machines have fuses? timer was bad, replaced timer, was for a different model, the machine hummed once now im getting nothing with either timer in the machine.
  • Anonymous Mar 10, 2009
    MY MODEL 80 KENMORE WASHER FILLED AND NOW NOTHING HAPPENS ACTS AS THERE IS NO POWER.
  • Whirlpool Master
  • 909 Answers
Timer is normally 2%of the problem. Usually if nothing happens at all, one would check incomming power, then door latch and or limit switch, then once switched off, inspect in control panel for blown fuse. It gets a little more technical after that as wiring sometimes runs through solonoid valves and motor windings to complete the circuit.
Posted on Jan 28, 2009
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Washing machine does not advance cycles automatically
More than likely a bad timer. You can buy the parts on-line, one source is repairclinic.com. Go to that page and enter your model number and look for timers. I found several there for your machine depending on the options the machine has.
Jul 04, 2014 | Kenmore Washing Machines
Direct drive-type Kenmore washer will not spin.
Check the video at the following link. I think you will find it helpful. Hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Sep 14, 2009 | Washing Machines
Sometimes the timer on my kenmore heavy duty series 80 is hard to push in to stop the washer. any help is appreciated
Hi, The only way to fix this issue is to replace the timer. It is starting to go bad inside.
Vic
Jul 03, 2009 | Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore 60 series will not drain
Well if this is a belt driven model then your solenoid coil is bad.
This model 's motor only revolves in one direction. To spin it has to shift gears. It does this by means of a solenoid mounted on the transmission called a wigwag. Note: if the lid switch is bad no power can go to the wigwag and shift it. If this is a direct drive model(no belt) then it has to be a bad lid switch.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Kenmore/works on one cycle only
that machine have somes burn contacts on the timer replace with a new one and that is...good luck
Aug 07, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
