How do i check oil level? - Heating & Cooling
  • 69 Answers
Go to your oil tank. If you have a basement it is probably down there otherwise its outside. on the top of the tank there will be a vertical plastic gauge with a line inside. The lower the line is, the less amount of oil you have. Just dont let it run out. Steve
Posted on Dec 21, 2008
1995 Yamaha SRX 400 Monoshock - How do you check the engine oil level. I.E. with the bike level or leaning over on its side stand?
Hi, Miketecham with the bike level engine oil hot for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.srx600.net/srx400/3vnengine.php&heading=SRX400(3VN)%20Info
http://www.apriliaforum.com/forums/showthread.php?82247-Checking-The-Oil-Level
How to check the Oil Level in your Motorcycle
Yamaha SR500 SR400 Forum
Yamaha SRX440 1980 Service Manual
Aug 11, 2016 | Yamaha Motorcycles
Buick riviera 1995 check oil level comes on
the oil level sensor in the oil pan is probably going bad.
Feb 03, 2012 | 1995 Buick Riviera
Just bought a 2006 Crossfire. The area where the (Trip Milage) is, a beep then the Oil Logo with the word HI comes on once a day at least. The Manual says the Oil has too much and the oil pan needs to be...
Yes its mentioned correct in manual.The HI indication comes on when there is about 1 quart too much oil. Get the excess oil drained.----------- CHECKING ENGINE OIL LEVEL:-------- A sensor in the oil pan allows oil level to be checked
without opening the hood. It provides an accurate measurement of oil level, whereas the low engine oil level indicator warns that oil level is definitely too low. With the vehicle parked on a level surface, the engine is warmed up and shut off for approximately five minutes.When the ignition switch is turned to the ON/RUN position, an ISO oil level icon appears in the trip odometer window and a "clock" icon in the cumulative odometer display. Pressing the knob to the left of the speedometer twice within one second displays one of the following messages:
• OK
• -1.0 Q (-1.0L)
• -1.5 Q (-1.5L)
• -2.0 Q (-2.0L)
• HI
The indicated amount of oil must be added to the engine
if the message -2.0 Q (-2.0L) blinks and a signal sounds.
The HI message indicates that the excess oil must be
removed from the pan to avoid possible engine or
catalytic converter damage. If the ISO oil level icon and
"clock" icon remain on when attempting to check oil
level and no message follows, or if the low engine oil
level warning lamp comes on, a malfunction in the
engine oil level system is indicated. A conveniently
located dipstick allows manual checking of the oil level.
If no leaks are noted, continue to drive to the nearest
service station where the engine oil should be topped to
the "full" mark on the dipstick with an approved oil.--------------------
Apr 09, 2011 | Chrysler Crossfire Cars & Trucks
I want to check the engine oil level for previa 2.4 petrol 1995
OIL LEVEL CHECK Every time you stop for fuel, check the engine oil as follows:
  1. Park the vehicle on level ground.
  2. When checking the oil level it is best for the engine to be at operating temperature, although checking the oil immediately after a stopping will lead to a false reading. Wait a few minutes after turning off the engine to allow the oil to drain back into the crankcase.
  3. Open the hood and inspect the level of the engine oil tank. The fluid level on the tank should read between FULL or F and LOW or L.
  4. If the level is below the LOW or L line, remove the cap and add enough engine oil to reach the FULL or F line. Fig. 1: Fill the engine oil tank located under the hood first 90911p07.jpg
  5. Install the oil cap and hand tighten.
  6. After filling the oil tank, remove the engine access hole cover on the drivers side. Fig. 2: Make sure the oil tank is to the F mark 90911p15.jpg Fig. 3: The oil dipstick is located under the driver's side engine access hole cover 90911p83.jpg Fig. 4: Place your finger through the hole and pull straight up to remove 90911p84.jpg
  7. Remove the engine oil dipstick and wipe it clean.
  8. Reinsert the dipstick, push it in as far as it will go, the pull it out and look at the level on the end.
  9. If necessary, insert more oil through the oil filler cap next to the dipstick, this will completely top off the system. Fig. 5: The oil dipstick has two markings for level check 90911p85.jpg Fig. 6: To fill the crankcase, remove the engine oil filler cap 90911p86.jpg prev.gif next.gif
Nov 06, 2010 | Toyota Previa Cars & Trucks
Where is the transmission dipstick in my manual 1.3 liter 1993 suzuki swift located and where do i fill it up?
LEVEL CHECK With Oil Level Gauge Fig. 1: Manual transaxle oil level check - with level gauge 84241046.gif
  1. Drive the vehicle to bring the transmission up to operating temperature.
  2. With the engine stopped, remove the oil level gauge front the side case of the transaxle.
  3. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  4. Wipe off oil level gauge with clean cloth.
  5. Fit the oil level gauge to the transaxle side case so that the threads rest on top of the case.
  6. Remove the gauge and check oil level. The level should be between FULL and LOW level line.
  7. If the level is below LOW mark, add oil until the proper level is reached.
With Oil Level/Filler Plug
  2. Raise and support the vehicle safely.
  3. Remove the transaxle oil level/filler plug.
  4. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  5. Transaxle oil level should be even with the bottom of the plug hole. If oil level is low, adjust oil level accordingly.
  6. Install transaxle oil level/filler plug and tighten to 40 ft. lbs. (54 Nm).
  7. Lower the vehicle.
Oct 17, 2010 | 1993 Suzuki Swift
Where do you check engine oil? Should there be a
hi,
you can check the oil level in your bike by using the "oil sight glass" at the lower part of engine in the left hand side of your bike, just below the left foot peg.there are two marks, the upper mark referring the maximum capacity for oil level and the lower mark showing the minimum level.The oil level can be anywhere between these two marks.Please make sure of two things while you check the oil level in your bike.
  • Run your engine for two min so that the oil is warm while you check the level.Never check the oil level in a cold engine.
  • Hold the bike in upright vertical position while checking the oil level.
I have provided an example picture showing the location of the oil filter in a Yamaha v-star.Hope your problem is solved.Please rate my solution as 8a0e22a.jpghelpful.Have a great day.
Mar 08, 2010 | 2001 Yamaha V Star 1100 Classic
Oil light on
first make sure oil level is up, then check or just replace oil preasure switch, if light still comes on, have your oil preasure tested, could be low oil preasure or electrical problem start there. good luck.
Oct 29, 2009 | 1998 Dodge Intrepid
Transmission fluid level check
The owner of the car should be able to check the oil fluid and coolant levels .get a clean peace of cloth.tools for removing trans axle /differential filing plugs. so that when the oil or fluid and coolant levels are checked they must be on desired levels.Locate the oil metering rod or dipstick and measure the lubricating oil level. Remove the transmission filler plug and check oil level. Remove differential oil filler plug and check oil level .Check fluid level .check coolant level.Observe all safety rules .Use the correct preventive maintenance procedures. If the owner can't do it then it is suggested that he should go to a car mechanic and the mechanic will do the job.
Oct 01, 2009 | 1999 Daewoo Lanos
Need to know how to check oil in transmition in a 95 ford aspire
Check the engine oil level every time you fill the gas tank. The car should be on level ground when checking the oil.
  1. Turn the car off and wait several minutes.
  2. Locate the engine oil dipstick and withdraw it from the tube.
  3. Wipe the dipstick with a clean rag and reinsert it in the dipstick tube.
  4. Remove the dipstick again, hold the dipstick horizontally and observe the level of the oil.
Fig. 1: Grasp the engine oil dipstick and withdraw it from the tube
Fig. 2: Observe the oil level on the dipstick and add oil if it is low
  1. The oil level should be at the FULL mark on the dipstick.
  2. If the level is at or near the LOW mark, replace the dipstick and add fresh oil to bring the level up to the FULL mark. Do not overfill.
  3. Recheck the oil level and close the hood.
Good luck, and remember rated this help!!!
Aug 18, 2009 | 1995 Ford Aspire
How to cheack the oil
there is a oil level window on the side of the motor when checking level have motorcycle upright and level you should have a low level line and a full line! pretty much any motorcycle grade oil avoid car oil it's not designed to work in a wet clutch enviroment also remember when changing the oil upright check level and top off oil after running engine 2 to 3 minutes (you have to fill the oil filter) wait 2 to 3 min. before checking level!
Jun 22, 2009 | 1990 Yamaha FZR 1000
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
