Question about Dell Inspiron 6000 Notebook
Laptop won't power on
My laptop fell off the coffee table and won't power on. Are there some simple troubleshooting tips I can do before taking it in to have it fixed?
It's a Dell Inspiron 6000.
Thanks in advance
  • Manny B?ez Feb 21, 2009
    My Inspiron 6000 just wend dead. It doesn't power up at all. What can i do ?
    Manny at mrbaez@hotmail.com
    Sergeant:
  • 324 Answers
As a start, I would suggest reseating the Hard Drive, Memory modules, DVD reader, and anything else that you feel comfortable in accessing. I would suspect that a component or cable was knocked loose by the fall. The problem may be more serious than this, but it could be as simple as making sure that everything that you can get to is plugged in solidly.
Best of luck and have a good day!
Ron
Posted on Dec 20, 2008
Won t start will not turn over no crank do have lights and battery
then I can only suspect the starter has failed .
Oct 24, 2015 | Cars & Trucks
Xbox fell while open now it won't close
its off track,,try pulling out ,,pushing left and right,,if still dont get it,,other option is to take it apart to fix,,good luck
Dec 27, 2012 | Microsoft Xbox 360 Console
Do I need a coffee table?
I personally think that every living room needs a coffee table. It seems to tie the room together and serves a purpose for magazines, remotes, little snacks when you watch TV, etc. I just think they make a living room look finished. If you have kind I'll have to go with a round coffee table so that there are no sharp corners so your kids won't get hurt.
Jul 31, 2012 | Furniture
My keurig won't even turn on. We unplugged and replugged but still nothing. The outlet does work, so don't know what to do. Is there a fuse or something simple that I could try. The Keurig is about...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 13, 2011 | Keurig B60 Coffee Maker
My laptop accidently fell off my coffee table on unto the carpet. I noticed some of the keys popped out. Can this be fixed???
Yes, this can be fixed as long as the key latches are not broken. If the keys just came out then they can be put back but it is a very time consuming and frustrating job if you do not have a lot of practice doing this. Your two options are you can try to follow this video and do it yourself or you could take it to a repair shop and they can replace these keys for minimal cost and time on your part.
Good Luck.
Apr 29, 2011 | Apple MacBook Pro Laptop Computer with...
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
We made hot water for coffee this morning and when I went to made the second mug the lights work, the timer worked however the microwave and turn table did not work.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Kenmore 62463 Microwave Oven
My computer fell off a table
Since your computer fell off a table this is definately a hardware problem, something might have shifted inside and in this case I would not recommend that you open it to see what shifted.
I would recommend that you take it to a repair store for them to pull it and fix it for you. Sorry to hear.
Jul 31, 2010 | Acer Aspire One PC Notebook
Hi , I have a Saeco Taleo coffee machine and have problems with brewing. The coffee get ground and then the brewing fails . Anu tips on what I need to look for ? Thanks Christina
Follow the below procedure to troubleshoot your Saeco Taleo coffee machine.
You go with the visual check first. Check on the electric cords, switches, timers, fuses, thermostats and heating elements to see if there are any damages components.
If there are some damages that are visible visually, get it replaced or repair it, if not, then you would have to dissemble the coffee maker to assess the thermal fuse.
Unplug the unit from the electrical receptacle.
Remove the carafe and filter basket. Also remove the water reservoir lid
Turn the coffee maker over and remove the screws that secure the case. Remove the case.
Take a look at the control cavity and assess. If it is a a case of disconnected wire, debris etc. simple fix, reassemble and test. If it is not so, continue to the step 7.
Use a multi-meter to test the warming and heating elements, the switch, thermostats and timer.
For any parts that is defective, work out the costing and if it worth the while, replace it.
Reassemble the appliance and reinstall the carafe and basket.
Top up the water reservoir to 50%, then test it by turning on the coffee maker.
The problem should be solve with the above troubleshooting.
Take care.
Jun 06, 2010 | Saeco Talea Giro Espresso Machine
Dell Inspiron 6000 Notebook Logo
69 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
